Stop code 24 - Computers & Internet
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
ErrorCode 24 is for corrupted drives or boot partitions
  • Boot the operating system CD
  • Enter the Recovery Console by pressing 'r' when prompted.
  • Then from the command prompt run "chkdsk C: /f"
  • OR....if that doesnt work..
    Inside your hard drive are typically 2 ~ 4 discs (called "platters") stacked on top of one another, and read / write heads between each platter which collects or writes information to the drive. Because a hard drive platter sits *extremely* close to the read / write head of the drive, a single particle of smoke traveling between the two could cause the head to crash. That being said, bad sectors on the drive may be a result of corrupt medium (perhaps as a result of a warped or chipped platter, for example).
    The disk repair utility in Windows XP, called ChkDsk ("check disk"), has an option to "scan for and attempt recovery of bad sectors". However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector.
    What you should do is:
    1. Attempt to backup all critical files on the drive (such as your documents, favorites, pictures, and anything else you can't download off the Internet or replace elsewhere).
    2. Following that, run ChkDsk and attempt to recover bad sectors. To do this, go to My Computer, right click your hard drive (C Drive?), select Properties, then goto the Tools options menu, and select "Error-Checking". A new window will appear. Select the option "scan for and attempt recovery of bad sectors".
    This test will take a while to complete.
    If ChkDsk reports a lot of bad sectors, visit the hard drive manufacturer's web site, download a drive integrity tool, and test your drive. To find out the manufacturer of your drive, right click My Computer, go to Properties, go to Hardware, then Device Manager, navigate to Disk Drives, and collapse the menu. Your drive should be listed there. If not, open up your computer and have a look.
    If the integrity tool reports many errors on the drive, you will need to ship it to the manufacturer for replacement (information for this procedure will be on the manufacturer's web site
    Posted on Jun 17, 2008
    Magiccard Rio printer is giving error code 24:24
    Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
    Mar 01, 2013 | Magicard Rio Card Printer
    Ford courier imobiliser code 24 while driving. Once stopped will not restart for a long time.
    to ford courier code 24, had same problem at work with customers ute, turned out to be a fault with the immobilizer built into the fuel injector pump. solution was to fit a change over pump.
    Jan 29, 2011 | Code-Alarm Code Alarm Transponder
    86 dodge Aries with 24 error code. Changed the tsp but still has the code and the power loss light came on again. Also has code 52(new) Car seems to go through a fair amount of gas, but that may be the...
    Code 24 will stay for 50 or so starts, but 52 is indicating a rich mixture. Possible oxygen sensor faulty. Clean connectors on oxygen sensor, and clean and check map sensor connection as well. Stop at an Autozone or Pep boys or similar parts store and they will scan and erase codes for you. Then see if code returns.
    Jan 07, 2011 | 1987 Dodge Aries
    I need ptcl phone lock code 0572520171
    Lock Unlock PTCL Code For Mobile & International Calls If you would like to stop making Mobile & International calling from your PTCL do following steps
    1. First call PTCL help line 1236 and ask them to open lock facility(it will take 24 - 48 hrs).
    2. Once facility is available you can lock phone by dialing *33*1234*4# (replace 1234 with your desired password).
    3. To unlock phone dial #33*1234# (Replace 1234 with your password).
    By doing this i lock my PTCL mobile & international dialing.
    Nov 05, 2010 | Cell Phones
    I bought a samsung impression on Ebay, and I dont know the password to unlock it
    • Unlock Type: Remote unlock code based on IMEI number , you will not have to mail-in your phone
    • Cable Required: No, simply dial in unlock code using phones keypad
    • Turn around time: Unlock codes are generated in under 24 hours Mon-Fri !
      Purchasing this service DOES NOT guarantee we will generate an unlock code for your phone within the time limit above. If 24 working hours pass and you still have not received your unlock code, you are entitled to cancel your order and receive a full refund or continue to wait.
      This service can stop at any point in time without prior notice, if this happens prior to receiving your code, you will be refunded within 48 hours of us being notified of this. Sea Breeze
    Jan 25, 2010 | Samsung SGH-A877 Impression Cell Phone
    My bosch dishwasher starts then stops with a error 24 code? It is just 3 days old.
    I have had a few people with the same my advice is to tell the comp. you bought it from it is under warrenty
    Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
    What does a code of F 24 indicate on the washer?
    Remove the bottom panel and on the side there will be a plastic bag with a tech sheet. use the sheet to run the diagnostic program and to see what the error codes mean.
    Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Telewest starview codes 14 feb 09
    00= KEYS AA B7 D1 D9 CE 8E 83 AF
    01= KEYS A1 38 06 29 24 29 8D 28
    Feb 14, 2009 | StarView SV211K 2-port KVM...
    Computers & Internet Logo
    1,628 people viewed this question
    David Payne
    David Payne
