Question about Poulan Garden
Why does my chainsaw stall out after running for a couple of seconds
    Brigadier General:
  • 4,088 Answers
You need to half choke after the first pop and be sure to set the fast idle button if it isn't automatically set with the choke lever. Open the choke fully and don't 'bump' the throttle until the engine is warm enough to allow it. Make sure the primer bulb (if equipped) has been pumped enough to pull fresh fuel through the carburetor before start. Make sure to have fresh fuel mix in the tank and to thoroughly shake the container each time just before adding to the tank to prevent oil starvation. Hope this helps!
Posted on Nov 11, 2010
3 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
Posted on Jun 10, 2009
SOURCE: homelite chainsaw starts and runs for about 30
Check your fuel lines for cracks it may be sucking air ,also make sure the fuel filter is still attached since they like to come off in the tank and then dirt gets in the carb,if thats the case replace your fuel lines and filter ,replace with fresh fuel (correct mixture ratio is a must). You may want to take the carb apart and clean out the small internal screen it has and look for any cracks in the diaphrams.You should also check your exhaust to make sure its clear of carbon build up.I repair saws , trimmers and many other 2 strokes and find most of the time its bad fuel lines and carbon in the exhaust port,but also alot of times I find damaged pistons and scored cylinders with very little compression.Good luck to you.
Posted on Aug 12, 2009
My stihl ms390 chainsaw starts and runs for around 20-30 seconds then stalls, i've taken off and cleaned the air filter and carburetor which both look fine, the diaphragm is intact too.
cleaning the carb might not clear problem may have to rebuild it also check fuel is correct and look at fuel filter inside tank
Oct 11, 2016 | Stihl Garden
Husquvarna 350 chainsaw won't stay running
There could be a couple of things wrong. Check fuel filter and fuel lines for integrity. Then check air filter. Replace sparkplug with proper resistor style plug. If the saw will still not run, check compression, should be between 120 - 145 lbs.
Still nothing, check to make sure ignition has good ground where it mounts on case.
May 10, 2014 | Husqvarna Garden
My Husqvarna 351 starts then stops after 1-2 seconds
Once the saw cools down will it restart and run fine? There are a couple other solutions that are not directly due to carburation. The first two solutions above are definitely your first options.
1. Ignition Coil: Highly unlikely, but possible. I seen some where they get hot and run fine while cutting, you shut it down for a few minutes for whatever reason and it won't restart or starts and stalls.
2. Crankcase Air Leak: We started to see more and more of these issues. There are a couple of quick ways to test this if you do not want to pay a shop to do an actual test. You want to do a cold test and a hot test. With a half tank of fuel, start the saw up for the first time of the day. While the saw is idling, turn the saw sideways from right to left, do this slowly, listen to the saw idle, if the speed changes by increasing or almost stalling, you have a crankcase air leak. Most bad air leaks won't be noticeable until the saw has gotten hot and the aluminum crankcase starts to expand a bit. Do the same thing once the saw has gotten hot. If this happens when it's hot, chances are that it won't start or starts and stalls until it cools down and everything retracts.
Test Results:
Sporadic idling when cold: Most likely just the oil seals, fairly inexpensive repair.
Sporadic idling when hot: Most likely crankcase itself is leaking, requires a complete crankcase gasket replacement. Can be fairly expensive to repair.
Apr 13, 2014 | Garden
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Husky 51 runs for a few seconds dies than when i open gas cap and put it back on saw runs a few seconds than dies
Check the fuel filter for plugging. Check the fuel lines for decay or other damage. If the cap vent was stalling the machine, removing it should allow about a minute or so of running before it quit again. Hope this helps!
Dec 14, 2010 | Garden
Won't stay running
HI. I THINK IF YOU PUT A KIT IN THE CARB I THINK THAT WILL FIX THE PROBLEM. JIMBO
Sep 15, 2009 | Garden
Stalling chainsaw stihl ms310
-check and see if the air filter is clean.
-check if you have your intake selected for summer or winter, you will find that on your air intake there will be a tab insert that has a sun or snow flake insure that this is in the proper spot.
these two items list are usually the cause of what you described.
Aug 30, 2009 | Garden
Runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
Dec 30, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
175 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
