Question about Zebra DS3478-SF Wireless Handheld Barcode Scanner
I have configued my bar code reader for font 128 but it don't read. My bar code readers LS2208 and DS6707 read well. Can you help me? Robert
pnevai
  • 48 Answers
SOURCE: Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Posted on Jun 29, 2007
  • 4 Answers
SOURCE: analys of how to connect java application to bar code reader
You will most likely need a java-bridge to connect to the drivers installed to run the scanner. Maybe google more on Java POS to find out more on connecting Java with POS Devices.
Posted on Apr 19, 2008
bluegreenash
  • 661 Answers
SOURCE: Can not scan Code 128 bar code
you should have a code book with the scanner setup barcodes in it, you need to enable code 128 by scanning the appropriate codes in the code book.
Posted on Sep 30, 2008
SOURCE: use of bar code reader to print on dymo turbo 300
what is the uses of barcode reader?..
Posted on Feb 04, 2009
  • 97 Answers
SOURCE: the printer will print a bar code but the reader
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Posted on Apr 08, 2010
What is error code 116 372
What are you trying to print? I've read a couple issues that it could be.
1. If you're trying to print PDFs, try using Foxit Reader or Nuance PDF Reader, instead of Adobe Reader.
2. If its a word doc, there's an issue with the Calibri font in Office 2010. You can either use a different font, or copy the Calibri font from a 2007 install. I'd give you more instructions, but I'm not sure of them. I know fonts reside in c:\windows\fonts but I dont know if there's any other place.
Dec 26, 2014 | Xerox Workcentre M24 Multifunction 24
I can't read a code bar printed with datamax a4212
try adjusting your darkness settings. if too dark wont read and also if too light wont read. also try a printhead test to make sure no elements are burnt out.
Aug 13, 2017 | Computers & Internet
I can't set to read a barcode 128 with symbol ls2208. I have scanned the "enabled barcadeo 128" on the manual but nothing happends... please help
Sometimes it can be something as simple as scanning another code and retrying. Don't forget to scan the save command.
Jul 06, 2011 | Symbol LS2208 Handheld
HI I HAVE ONE MOTOROLA SYMBOL DS6707 BARCODE READER TODAY ONE PROBLEM OCCUPIED. ANY MOBILE IMEI CODE SCAN BUT BATTERY NOT SCAN. SO PLEASE HELP ME
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode. Set the scanner for two specific lengths or for any length of barcode. Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
Nov 04, 2010 | Symbol DS6707 Wired Barcode Scanner
Hello, I have the Motorola LS3478-FZ barcode reader and am having a strange problem. This is a wireless reader, and the cradle is plugged in via USB. The reader seems to scan any barcode I give it,...
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Aug 19, 2010 | Zebra LS3478-FZ Handheld Rugged Cordless...
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Is the ds6707 compatable with windows 7?
If connected with a CBA-U01-S07ZAR and programmed as the default HID keyboard USB host type, yes it should be compatible. The device uses the same drivers the host uses for a USB keyboard.
Jun 22, 2010 | Zebra DS6707 Bar Code Reader Barcode...
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
Sep 26, 2008 | Symbol LS2208 Handheld
Zebra DS3478-SF Wireless Handheld Barcode Scanner Logo
29 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
