Question about Onkyo HTR500 Receiver
I have the the HT-R560, How do I connect my Apple TV so that I get an image? There is an HDMI cable from the Apple TV to the HDMI input but no image/signal to the TV. Help
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Posted on Jan 27, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Posted on Jan 08, 2009
SOURCE: No video throught HDMI output
I have solved this problem. I've managed to get my Sky HD and Playstation 3 to play through the amp. You setup the HDMI inputs in the Input/Output assign. Once you have donew that go to the 'Source Setup' menu, select 'A/V Sync' then press enter as requested, you should then see an image. This worked with me after fiddling around with it for a while but it does work.
Posted on Feb 01, 2009
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
I am trying to connect my new apple tv to my panasonic bt205 ht and then to my samsung tv. As I have only i HDMI socket in my Ht I bought a HDMI splitter. This doesn't seen to work. If I connect the...
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
Aug 04, 2011 | Audio Players & Recorders
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
Have a HT-X810 Samsung soundbar but cannot get any signal to the TV from the HDMI for playing DVD's. Works ok with scart but nothing out of the HDMI. Second unit this has happened on - am I doing something...
Dear rayoneill,
I just got an HT-X810 and hooked it up to my TV and had the same problem. I suggest that you ensure that you've selected the proper device input on your TV. My TV has a couple HDMI ports, in addition to a host of other connection choices, and I found that I was selecting the wrong HDMI input for viewing a dvd. Alternatively, when I was looking for an HDMI cable to hook up my unit I came across many chats/discussions/reviews that noted the properties of HDMI cables. The consensus among the discussants was that an HDMI cable either works or it doesn't - meaning that if there is a problem with the cable, you don't get a degraded image and sound you get nothing. Things that may lead to this include a loose connection or perhaps, and there was some disagreement among commentators on this, a poorly manufactured HDMI cable. Many claimed that due to the nature of digital signal transmissions, all HDMI cables are created equal so quality doesn't matter. However, when I was reading product reviews for cables available on amazon.com, many people were very critical of the cheap cables' performance. At the same time, most everyone seemed to agree that expensive 'Monster' cables were a waste of money. I settled on a $10 HDMI cable and haven't had any problems.
Good Luck, Justin
Nov 29, 2008 | Televison & Video
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Onkyo HTR500 Receiver Logo
134 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
