Question about Ford Tractor Naa Golden Jubilee Emblem
Install a new selenoid & I hook up the battery, And the tractor want to start??? I think the wireing is hook up Okay. Don
  • 297 Answers
Hey don,
The key switch supplies power to the coil, it has nothing to do with the cranking circit. When you press the start button it supplies power to the solinoid, that in turn activates the starter motor. You can crank the engine even if you dont have power to the coil. Which is what I think you have happening. On the coil it has two small wire under two small nuts with a big wire in the middle going to the distributor. The two small wires are marked with a + and -, The + side should have 12v with the key turned on and 0v with it in the off position. The - Negitive side goes to the points. Check the points for burned, stuck, worn out lob on cam, if you have no spark. If you have spark, you need to address the fuel, Try spraying carburetor cleaner ( not either) into the carburetor to see if it fires then quits, this proves you have a fuel issue.
Make sure your battery is fully charged, and that the ground is a good one.
Hope this helps
Posted on Nov 12, 2010
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Need a wiring diagram for 1986 ford mustang 4cyl engine. Helping a friend with his 4cylinder mustang and when i installed the negative terminal on the battery then as i place the positive terminal it...
Hi!!
You may have the positive cable hooked in the wrong side of the starting selenoid or the starter selenoid is defective.
Follow the RED (+) cable from the battery, it goes to the starter selenoid wich has two terminals, change the cable to the other terminal, that should take care of the problem unless the selenoid is stuck on. Replacement runs about $15.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | 1986 Ford Mustang
Will not start
clean and tighten all connections from the positive cable all the way to the starter and selenoid connections too and try jumping the selenoid across and see if that kicks the starter over if it does that means the selenoid is bad
Jun 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere 2010 utility tractor, lights come on dash board, but it wont start. Its in neutral, PTO is okay, seat switch okay
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a1994 ford f-150, battery fine, but it
Very possible that selenoid is bad-did you have starter tested?(auto parts stores do this)Check all cables going to starter for corrosion and loose connection at starter. Corrosion gets inside of cables over time, so replace when in doubt. INSTRUCTIONS-remove negative cable from battery and move away from battery(tie off), on selenoid if fender mounted, remove cables from both sides of selenoid(is stamped with letters B and I)-when you remove, mark with tape which is I and which is B, in case replacement is different from old unit. then remove from fender(save bolts)-install new part on fender, and replace cables on proper sides(B or I). install neg. cable on battery-try to start....good luck!!!
Nov 08, 2009 | 2004 Ford F150
I just put a new battery in my Craftsman LT1000 & it stalls out?
MAKE SURE YOU DIDNT HOOK THE WIRES UP BY MISTAKE. I HAVE SEEN THIS HAPPEN MORE THAN YOU WOULD THINK.IT OVER LOADS THE CHARGING SYSTEM AND SHORTS IT OUT
Jul 26, 2009 | Garden
Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Jul 18, 2009 | Garden
It won't start
do you have power to the solenoid?? with the key on there should be 12 volts on one side of the solenoid then when you turn the key to start it should send 12 volts out the other side to the starter
Apr 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hooked battery up wrong when jump starting lawn tractor
there a fuse in the power wire you probly blew it!!
its in the wire coming from the + side of the battery too the switch then too the starter!!
Apr 13, 2009 | Garden
Ford Tractor Naa Golden Jubilee Emblem Logo
141 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
