Question about Whirlpool Dryers
AWZ8578 condenser dryer - all red lights flashing - have emptied and cleaned all filters but it wont wok
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 139 Answers
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
SOURCE: Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Posted on Jan 10, 2009
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
Not sure but try this..it workd with my Whirlpool dryer. Remove the condenser (clean it with water and a toothbrush too coz it will probably be clogged up) and pop a tea towel in the hole where the condenser was. Tip the dryer on its side and any trapped water will run out onto the tea towel or the floor OR the water reservoir where it should have gone in the first place......
Posted on Mar 13, 2009
tony2155
  • 64 Answers
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
bad sensor or dirty
Posted on Jun 23, 2009
Dyer showing FO4 WONT START
MAY WANT TO CHCK UR THERMAL SHUT OFF FUSE OR UR DOOR SWITCH
Feb 25, 2015 | Maytag Dryers
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Whirlpool tumble dryer
I don't know much about Whirlpool, but do you need to empty the water/fluff filter or clean the condenser?
Dec 27, 2013 | Dryers
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
My whirlpool condense dryer 6th sense the light keep flashing red saying clean filter, empty bottle and heater exchange I have done all that and it still won't work can you help please.
Have you tried unplugging it from the power source and then plugging it back in? This may prompt the mini computer inside the dryer to reset to the proper default settings. Best of luck!
Jan 15, 2013 | Dryers
Model: LG Steam Dryers DLEX2501R Problem: Shows "Check Filter", while dryer still does the job
do you mean a condenser dryer?, as steam is water doesn't dry anything to well, if it is a condenser dryer the check filter or clean filter light should always come on towards the end of the cycle (varies between models some have both clean filter and empty tank lights on at end of cycle just as a reminder to do so and some don't have any lights), it is simply a reminder for you to clean the filter after each use unless this is something that has only just recently happened
Apr 17, 2011 | LG DLE2514 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
140 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
