Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
I am unsure which model of TV I have. The manuel lists 4 HD 61Z585 HD-52Z585 HD-61Z575 HD-52Z575 The color is messed up. I know it is more than an adjustment. I am sure it needs a new part, just don't know which one.
  • 7 more comments
  • msjanuary Nov 11, 2010
    The color simply comes and goes....so I know its some kind of tube going out. I will take a picture. But the picture itself is fine. The color is all jacked up. There is a lot of blue and yellow in it, it seems like its missing some colors.
    I have uploaded a photo,
    Yep, always have a picture. So when I buy a new "color wheel" module or whatever they call it. Can I replace it myself, like I did the picture tube thing? Which model do I have, does it matter and where is the model number?
    I think you were right the first time, it's a color chip thing. I replaced a big bulb thing when the entire set wouldn't come on.
    I replaced the lamp.
    so it's not my chip drive that has gone bad? just the bulb things. And aren't all of them going to go at some point? do they go in sort of like regular light bulbs?
    When I try to google the parts for my TV, they don't show it having these parts. So I am confused. They say they don't have color tubes, they say it has a 3 chip direct drive image light. JVC is the one that developed that. Are you sure we are talking about the same TV?
    I would like to get information from a different guy please.
    Yes
  • 10,515 Answers
From the information you have provided the problem is with the convergence. If you have gone into the menu and tried adjusting the focus/conversion after the TV has been on for an hour or more and the focus did not correct the problem the convergence ICs have failed and will need to be replaced along with a few defective resistors. If all the colors are incorrect a open fuse in the voltage supply to the amplifiers is possible. A TV repair company will normally charge about $350 for this repair if the ICs are the problem, less for the fuses. Small TV repair shops will normally charge less than large repair facilities. Convergence failure is a very common problem with this TV set. There could be other parts that are not within factory specs. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
If you wish to repair it yourself and can solder, I will suggest that you to purchase a kit that has all the needed parts and detailed instructions for making the needed repair from :-
.When you get to the site using the link provided, choose TV repair kits, enter in the model number for your TV and select convergence repair kit.
I am sorry, you need to confirm the model number. There should be model number engrossed, might be back of the TV .
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 11, 2010
  • 4,889 Answers
What exactly do you mean by color is messed up? If you can just upload an image to imageshack.us and get me the direct link, I can tell you what the problem is.
  • 5 more comments
  • eagle338
    eagle338 Nov 11, 2010
    When the color comes and goes do you still have picture? If yes then these are tell tale signs of the color wheel going bad. Replacing it should resolve your problem.
  • eagle338
    Sorry about my last response. I just checked and found that this is a CRT rear projection tv.
  • eagle338
    Well in CRTs this is related to the tubes themselves. Red and Blue are malfunctioning. Which one did you last replace?
  • eagle338
    Your should replace the blue and red CRT guns to resolve this problem. My first diagnosis was a mistake as I thought that your set was DLP. The CRT guns re the bulb kind of things located at the back of the set and glow when the set is turned on. Each tube will cost you around 100-150$. This is what they look like
    http://members.cox.net/pminer/rearprojec...
  • eagle338
    Which one? All 3? If yes then are the parts under warranty? Coz the problem clearly indicates that two of the three CRTs are malfunctioning. Blue and red. Only gree is working as it should.
  • eagle338
    No they not go off together. They are three seperate tubes, and yes then can go off separately. They are not bulbs they are cathode ray tubes.
  • eagle338
    Ofcourse I am sure. Here. Read the title bar it says 56" Digital CRT PTV
    http://support.jvc.com/consumer/product....
Sony rmt-b118a hd code
If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.Check this site too. http://electrohelponline.blogspot.com/
Apr 27, 2013 | RCA RCU410 Universal 4 in 1 Remote...
I need a users Manuel for my 57' Mitsubishi HD
I'm sorry for the difficulties you're experiencing in getting the Manual of the TV. Please click hear to download the same.
Please let me know if you require any additional help.
Aug 09, 2011 | Televison & Video
I just need to know if it is multi system. I live in Germany right now and need to know. I lost the manuel and it doesn't say on the tv.
I am not sure what you mean by a Multi-system? But I can tell you that replacement manuals are available on line for free on their website. The Regaza is a US model and the website to locate the manual is on www.us.toshiba.com. Click on Customer Service and then tv's and LCD then scroll the model numbers listed to find yours and click on it. There is troubleshooting and chat services available in that area. Hope this helps?
Jul 04, 2011 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
Connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
May 03, 2009 | iLO 3200 32 in. LCD Television
Rca big screen
Whats your model number. I can assist you with this repair.
Jun 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color is Messed up
you need to replace your convergence ic's give me your model number and I'll be able to tell you what ic's you need and a link to where you can buy them and get free installation instructions and free online support so you can do the repairs yourself
Apr 08, 2008 | Televison & Video
HD Problems
ya buy new hd antenna non powered sound like antennna messing up
Jan 06, 2008 | Televison & Video
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
234 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
