Error sc548 on a ricoh 1027 just did maintenance must of turn on before fuser installed , how can i reset?
  • Jimtyping Jun 30, 2008
    We have the same error code. We need someone who can advise us or repair this machine. Please send reply to Jimtyping@Gmail.com
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working
Posted on Aug 26, 2008
  • cedrickit Sep 02, 2011
    Thank it works!!!!!
  • Marcio Cajas Dec 12, 2011
    QUE ES UN SP, SC , GRACIAS DISCULPE YO NO SE DE ESTO
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Mar 11, 2011 | Office Equipment & Supplies
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
Have a Ricoh 820dn printer.. sucked in a bunch of pages from the bypass and now has error code SC548
It's fuser code, could be the fuser unit is not set correctly. In any case you to do a SP- 5810 reset first, to see if it clears.
Apr 01, 2010 | Ricoh Aficio SP C820DN Laser Printer
Error sc548 aficio 1022 ricoh
Poor connection of the fuser, and the code will need to be reset in service mode.
Jul 17, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code sc548
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps.
Jul 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 326c SC548
Fuser error. Problem needs to be repaired, and the code can only be reset in service mode by a technician
Apr 17, 2009 | Ricoh Office Equipment & Supplies
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
3,584 people viewed this question
jasbo
jasbo
