Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Print is OK - both black and colour. Copy and scan does not function - paper gets totally black.
  • HP Master
  • 7,733 Answers
Canon MP110 running Windows 7 with corret software will not print colour nor will it read colour in scan.
Can you try to do COPY function?
If COPY function fail,means the machine in fault. Most probably is PRINT HEAD in fault.
Nov 24, 2014 | Canon Office Equipment & Supplies
Hi, I have xerox phaser 3100 mfp , when I try to copy or scan, only I got a black paper and not clear at all,,,, but when I try to print from the computer, it's OK... so what is the solution,...
The problem is with the hardware of the printer and all you can try is to reset the scan settings on the scanner .. clean the scan bed.
If neither of them works then it might be time to buy a new one.
Oct 25, 2010 | Xerox Phaser 3100MFP/S Laser Printer
When I scanto Paper Port, I get a black and white copy. When I scan to my pictures I can get a color print
You can change colour option is scanner software from where you scanned. For that before scanning open that software then go to it's settings and change scan option to color if you want color. Let me know if you need further assistance. Thanks for using FixYa.
Sep 15, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
Sir, I am having IR400, the copy became white coloured font with very dark black background, so i replaced drum & blade and then copies became normal, but very light, then i increase the density from 5...
Why did you do ccd-adj before cleaning the optics?
in copiers front door must be sheet with numbers that are factory input, do the clear all, and then set the values from paper in service mode.
May 18, 2010 | Canon imageRUNNER 400S Copier
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
HP F2180 not scanning
I was having the same trouble. All you do is turn the printer on and make sure there is paper in the tray for it to print onto (obviously), then lift the lid (keeping it open) and place the piece of paper you are scanning onto the glass. The side you want to scan needs to be face down in the bottom left hand corner. Then instead of pressing the scan button (which did nothing for me either) press the black or colour button that is above it, depending on whether you want to scan in colour or just black and white. Worked for me! Hope it works for you too.
Feb 10, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
IS IT POSSIBLE TO GET A TEST PRINT OR SCAN TEST WITHOUT THE X1180 BEING CONNECTED TO A PC?
No, if you print or scan, you need always to store the file on a computer, and if you use copy function, you still need the computer, as copy function allowed on this printer is only Colour Copying with PC .
This printer cannot print, scan or copy if it is not connected to a computer.
Oct 10, 2008 | Lexmark Office Equipment & Supplies
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
291 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
