Question about Jenn-Air Ovens
Key do not work #'s 1 & 2, Lower bake , broil, cancel and timer #1 with F5 fault code. I have replaced the display board.
  • ltanman1 Nov 11, 2010
    model # ww27430w
    The temperature sensor, checks out and so do the contacts on the PBR
  • 4,323 Answers
Hi
You'll need to check the oven temperature sensor and the contacts on the power relay board (PRB). You'll need a multimeter to check the resistance of the temperature sensor, multimeter would read between 1140-1150 ohms. If you notice any deviation in the reading then you'll need to replace the temperature sensor. Hope this helps... Please post back with model # if you need more information.
Daniel
Posted on Nov 11, 2010
  • Daniel Scott
    Daniel Scott Nov 11, 2010
    Hi
    Please check part#12 (temp sensor) in the diagram---
    Check the sensor using multimeter. It should give reading between 1140-1150 ohms.
    Part#11- Relay Board(PRB). Check the connections on this board.
    Hope this helps... Please post vack if you need more information.
    Thanks
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
Tip
My Whirlpool oven wont work, and I get error code E1-F5 on display.
Hi.
On Whirlpool ranges the error code E1-F5 means that there is a problem with the door latch switch or with wiring to door latch.
Try first disconnecting power for five minutes, by either tripping circuit breaker or disconnecting power cord.
You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minute to clear F5 failure code from ERC internal EPROM.
If that does not work, then there is a fault.
Disconnect power, access the door switch and testwires and connectors going from electronic control board to the doorswitch. An easy way to test wiring is by reading Ohms on the wire. Ifthe circuit is closed, the tester will read zero or low impedance, thatmeans that the wiring is good. If the multimeter set on impedance readsopen (no continuity), that means that the wire is broken and the wiringharness to the door latch must be replaced or fixed.
If there is no problem with the wires from Oven Electronic Control toDoor Latch Switch, then the door switch is probably faulty.
The switch can be tested reading Ohms on its contacts, and checking ifthe switch is opening and closing circuit while actuating the switchwith a pointed object at the same time.
If the switch is faulty, then replace the door switch.
After repairing the wiring or replacing the switch connect power back.You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minuteagain, to clear F5 failure code from ERC internal EPROM. When F2 isshown on display, push the Cancel/Clear button again and observe theappliance working testing it again, to ensure that the repair had beensuccessful.
The tip is not only valid for Whirpool ovens, but also works on other brands that had been built by Whirlpool.
Best regards.
Ginko.
on Mar 22, 2010 | Ovens
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Oven gets a "fault" shortly after putting power back on.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%#TR
May 30, 2010 | Whirlpool GBD307PDS Electric Double Oven
ACCU BAKE codes come up e6 f2
You have the following error.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
ONLY BROIL WORKS, NEED BAKE TO WORK BEFORE THANKSGIVING
I'll presume you have no "fault code" appear in the display, i.e. F30, F31 correct ? Is it both top and lower oven ? What happens when you select a bake cycle, anything ? Does it appear to be on, but no heat ?
Just need some clarification and details and I'll try to help.
Oct 30, 2009 | Thermador SMW272 Electric Double Oven
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
