Question about Canon PIXMA MP510 All-In-One InkJet Printer
Canon error code 5200 mp510 - Canon PIXMA MP510 All-In-One InkJet Printer
SOURCE: Canon MP510 Error code 5100
Ink cartrige is in the wrong slot and now oth are stuck!!! what do i do????
Posted on May 21, 2008
  • 34 Answers
SOURCE: canon pixma i6000d error code 5200
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Posted on Jun 28, 2009
  • 117 Answers
SOURCE: canon mp510 error code 5400
Paper feed error [5400] Replace the printer as it has failed.
Posted on Oct 13, 2009
MUKHTAR
  • 2022 Answers
SOURCE: service error 5200 for my printer Canon S200SPxhow
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 26, 2010
nonontech
  • 4737 Answers
SOURCE: error 5200
This error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
Let's begin like this;
Remove all the old cartridges, Turn off the printer, disconnect the all the cables including power cord and ethernet cable (if any), leave it Off for few minutes and again turn it on after connecting the power cord. Now install all the new cartridges and check if the error message is still there or not (Hope it's gone, but you need to find out the culprit from among the old ones so that you can use those that are functioning properly).
Now remove one for example yellow and install the old yellow and check the message, if it's ok, go on replacing with the corresponding old cartridges after removing the newly installed, and so and find out the cartridge which is the creating this problem. After that, you'll be able to use the other remaining old cartridges.
This might be a problem for you if you don't have a new set of cartridges, but this is the best way, you can also use old working cartridges [those with no more inks].
This will definitely fix. I would also suggest you to clean the contact points on the cartridges and on the printer properly using soft brush/cotton dipped in alcohol/acetone/spirit.
Good luck.
Thanks for using FixYa.
Posted on Jul 09, 2010
Canon pixma mp510 error 5200
Go to this website and look at the answers. Good luck.
Jul 22, 2013 | Office Equipment & Supplies
I have canon MP510 and I have a probem because my canon have a code 6800. What can I to do? Pleas for helps
Unfortunately error 6800 is an eeprom write error. You will not be able to cure this without replacing the scnt board (main board). The cost of a new board and labour would almost equate to the cost of a replacement machine. Cut your losses and buy another machine. Srri
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon MP510 printer won't scan from its program in PC-code 1,0,0
The problem was that all of the C.D. files were not loaded at start up. Thank You for Now. AEF
Feb 25, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Mar 31, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
400 people viewed this question
old marine
old marine
