Question about Williams 6508732 Gas Heater
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
  • kristinzydzi Nov 11, 2010
    There is also a red button to the right of the on/off valuve for the pilot light...is that the knob you are speaking of that needs to be pressed down?
  • Williams Master
  • 8,220 Answers
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Posted on Nov 11, 2010
  • Dan Webster
    Dan Webster Nov 12, 2010
    Post a picture of it.
  • Dan Webster
    Turn that gray knob there to the PILOT position. Press down and light the pilot. Hold the knob down till the pilot stays lit and then advance the knob to the ON position.
Old wedgewood oven in home...very low pilot light in oven...how do I adjust it?
The oven pilot is usually located at the back of the oven; turn a screw on the pilot ignition unit to adjust the pilot flame height.
here is a link, pretty much all older ranges operate the same.
Gas Oven Pilot Lights Shutoff Valves and Ignition Systems HowStuffWorks
Feb 05, 2015 | Kitchen Ranges
Rheem Power Vent model RN 21-VP40-1 gas water heater no hot water but venting runs. Is it the ignitor or the thermostqat? About 10-12 years old.
it may be the thermal coupling that is bad for the pilot light. if it goes bad the flame will go out. replace thermal coupling. so if the pilot light is out then it will not heat water. or turn burner on.
Oct 28, 2010 | Rheem Water Heaters
Where is the pilot in my hotpoint oven?
As far as I know, there is no pilot light in any domestic oven up to 25 years old and probably even in the older models.
Nov 26, 2009 | Hotpoint RGB745 Gas Kitchen Range
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Amana gas dryer
there is no pilot it has an ignitor bar that glows when it lights the gas.
Sep 03, 2008 | Amana ALG331RAW Gas Dryer
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Older Sony Trinitron (over 10 years old)
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Be careful on buying a new one though. Often times, they are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Jan 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Williams 6508732 Gas Heater Logo
323 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
