Question about Dimplex Heating & Cooling
Dimplex duo 500i - making ticking noise? - Dimplex Heating & Cooling
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Radiator rattling Noise
You are going to have to take it apart to see if something is loose in the fan.
Nov 11, 2013 | Dimplex Epx1250 Panel Heater
Dimplex stove screeching noise
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 26, 2012 | Dimplex Compact Electric Flame Stove...
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
Whatever rotates inside is making a lot of noise.
Call Dimplex @ 1-800-668-6663 Ext# 358 These folks will be able to help you.
Jan 19, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex FXL24n wont heat up over night
the clip should click and the heater reset its self have you repalaced the clip ? some times you have to press the clip hard to get it to click
Nov 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
69 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
