Question about Proform XP 542S TREADMILL Drive Motor
The belt is dragging and sticking... - Proform XP 542S TREADMILL Drive Motor
  • 42 Answers
Hi if the belt is dragging and slipping when your standing on top that means you need a new belt, not the one you are standing on. the belt that is attached to the motor. if you start the treadmill and dont step on it i bet the belt runs smoothly. not that expensive to repalce under £20.00. hope i have helped
Posted on Nov 14, 2010
How do I transfer movies, from a usb stick onto my Apple Mac laptop, then back to another usb stick
1. Plug in first usb stick
2. Open finder and locate the usb stick and the movies within
3. Drag and drop the movies on to the desktop
4. Plug in the second usb stick
5. Open it in finder
6. Drag and drop the files from your desktop to the usb stick
Feb 06, 2016 | Apple Computers & Internet
How do I save (copy of)a text onto memory stick?
Try drag and drop.go to my computer click on the icon for USB stick then shrink the window of the document you wish to save or locate its folder ...then drag the folder into the window of the USB stick .it should copy the file but leave an original in my documents.
Jan 26, 2015 | Cameras
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
THE RECORD DRAGS, THERE IS A SMALL BLACK BAND LYING INSIDE THE BOTTOM UNATTACHED WHERE DOES IT BELONG
thats the drive belt for the record [layer, it loops around the entire disc on the bottom plate and the small spindle that sticks up off the top of the motor drive
Jul 19, 2011 | Philco 841205 Turntable
Cant copy a program on to the memory stick.
With which mouse button do you grab and drag the memory stick icon? If you're using the wrong button, that can adversely effect the process.
Good Luck,
-a.
May 25, 2010 | Microsoft Windows Vista Home Premium with...
My belt broke as I was rotating the drum with the dryer off to clean the inside of the drum. the drum does not turn freely nor did it prior to the belt breaking. Could there be something else wrong beside...
There are drum felts / seals in the front and back of the drum. If either of them are overly worn the drum will drag. Also if an article of clothing got wedged in either of the seals it will act as a brake.
Before you head off for a belt I would gain access to the drum and check the drum seals and the rollers underneath the drum. If the rollers are sticking that too will make the drum hard to turn. When the drum rollers stick they usually end up with flat spots on them and must be replaced.
Thanks for using FixYa.
Kelly
p.s. dont forget to reconnect the door switch if you took off the front panel.
Mar 05, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
Aug 11, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I cannot transfer photos onto my memory stick from windows photo gallery on vista home premium. I right clicked on the folder name looking for either ''send to'' or ''save'' so I could transfer the whole...
Drag and drop. open my computer and select source file, then click my computer again and select the memory stick ( you should have 2 open windows, best if minimilised ) then just drag and drop. Mouse over, left click and hold the left button drag the picture(s) to the stick and let go of the left button.
Apr 26, 2009 | Computers & Internet
Thorens TD 126 Mark III - Motor will not run with belt attached
Maybe next time you might turn it OFF before handling the belt.
Try this with power off - manually rotate the turntable and look for where drag might be. You should be able to feel the drag. It is possible you didn't route the belt properly.
Apr 04, 2009 | Audio Players & Recorders
Proform XP 542S TREADMILL Drive Motor Logo
517 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
