Question about Dmm Mansfield 119CL EcoQuantum Toilet Tank & Lid w/ Cover Lock
I have an EcoQuantum dual flush toilet, all of a sudden it flushes sometimes & sometimes it won't flush at all. I push the handle down/up & nothing happens. Water pressure has not changed at my house. Any suggestions?? My bathroom sink lost pressure recently, but I unscrewed the faucet head & washed out the grit/sand (our lovely city water) & it was back to normal. Thanks for any help you can provide!
  • Mark Wathern
    Mark Wathern Mar 30, 2015
    You can also try stretching the springs in the handle, below the two plastic hex nuts. This sometimes fixes it.
  • 3 Answers
EcoQuantum B8100 is junk in my opinion. There is an obvious design flaw in the handle. The flush/no flush problem lies there. If you contact the company, you can get another handle from them, and problem will be solved. However, it WILL happen again in a year or so, and you will come full circle. Their number is 1-800-391-9821.
Posted on Mar 30, 2015
2 Suggested Answers
bloues
  • 56 Answers
SOURCE: One of our EcoQuantum toilets really doesn't
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Posted on Jul 10, 2010
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
Fluidmaster Dual Flush Valve S2DBL won't flush.
Fluidmaster S2DBL Dual flush valve - would not flush
The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved!
RAP
Jan 29, 2012 | Home
Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
One of our EcoQuantum toilets really doesn't flush. It flushes part way, but only pushing the handle down; it does nothing pushing the handle up. We have to flush several times to get it to work. What do...
Hello
Jul 02, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
May 30, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Dmm Mansfield 119CL EcoQuantum Toilet Tank & Lid w/ Cover Lock Logo
887 people viewed this question
Top Dmm Home Experts
Donni Steen
jdthefixer
john h
Are you a Dmm Home Expert? Answer questions, earn points and help others
