Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer turns on, but doesn't get hot. Then after 5-10 mins it shuts down. When this happens the display has dashes running around the outside edge of it.
  • Frigidaire Master
  • 8,220 Answers
Your heating element may be broken. The innards of your dryer have not changed from the old style that has been around for years and years My dryer turns on, but doesn't get hot.  Then - themobilian_105.jpgthemobiliaMy dryer turns on, but doesn't get hot.  Then - themobilian_107.jpg_mithemobilian_107.jpg
To get inside the newer machines you remove the top first, then the controls, then the front, and then you can get the drum out. It is kinda hard to explain.
I have a manual for late models and more repair photos HERE
Posted on Nov 11, 2010
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
how long is your vent hose and how long when heated it may be kinking when heated
Feb 26, 2009 | Maytag MDE2706 Electric Dryer
I would take and get a lint brush and clean the hose and I would also make sure you clean the pipe that is running on out side plus make sure the flap is opening up outside like it should .
Feb 26, 2009 | Dryers
Dryer runs for about 20 minutes when good and hot then shuts off.
suspect motor overheating and shutting down on thermal..if dryer does not have good air flow through vent to outside lint can accumilate around motor causing overheat and motor failure try cleaning around motor but i suspect it's too late damage has probably already been done
Nov 20, 2008 | Kenmore 63942 Dryer
Dryer keeps blowing the fuse in the fuse bow
check your venting going to the outside it sounds like it is clogged run a load with out the vent connected to the back and see if it works ok if so you need to brush clean the vent to the outside
Jan 21, 2008 | Kenmore 63932 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
67 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
