Question about LG LFD25860
Plastic water line from fridge pump to water filter is ruptured need part number
    Problem Solver:
  • 13 Answers
What you should do is take out the broken one, and look for printing on it as to what size it is. In our LG, I believe it was 5/16" inner diameter, but yours could be different. Just about any hardware store will sell polyethylene tubing, and you can just buy a few feet.
Posted on Aug 30, 2011
Ice maker in not working
A lot of times the reason the ice maker is not working is 1 of 2 things. First I would check the water filter if the fridge has one, and make sure it is new, or replace it if it has been over 3 months (depending on the fridge and filter, could last longer). If you replace the filter and the ice maker is still not working, be sure to check the water line going into the fridge, if it is a plastic line (soft to the touch) make sure to squeeze it ever so gently to see if water is flowing through the line properly. If so then, you may need to turn the water off to the fridge and disconnect the water line from the fridge to see if it is clogged, if so it could be clogged with calcium deposits, if not then the mechanism for the ice maker it's self could have gone out and needs replaced. This all depends as well on how old the fridge is. If the ice maker has a metal bar, be sure it is in the proper position to make ice, a lot of times they get broken and need replaced.
Apr 08, 2014 | Refrigerators
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
Water come's out to slow? changed filter! was doing it before i changed filter!
James -
Check to make sure the valve for the water supply is on fully - and not between the ON and OFF positions. If that is ok, the water supply line may have become restricted when the fridge was pushed into position the last time it was rolled out (for cleaning, etc.). The line may have become kinked (usually a copper line problem) or partially crushed (copper or plastic) under one of the fridge's rollers.
You should close the water valve before moving the fridge for inspection. Unplug the fridge. Disconnect the water line at the back of the fridge. Inspect the length of line for evidence of a crush or kink. Replace as needed. Test the flow of water into a larger container before reconnecting to fridge. If close to the fridge output, the valve and line to the fridge is suspect. Replace parts one at a time as needed until the problem is solved. If there is significantly more flow than when connected to the fridge, then the problem is somewhere in the fridge - but outside of the filter - there's little to change or go wrong for a "slow flow rate". It's usually an "all or nothing" deal inside the fridge.
Reassemble, turn water supply back on (check for leaks), plug into power, carefully roll fridge into position (watch the water line as long as possible to prevent crushing / kinking) and test.
Please rate this reply if helpful - good luck!
Aug 09, 2010 | Kenmore 77719 Side by Side Bottom Freezer...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Water dispenser is slow
There is no pump in this refridgerator to provide cold water. Water arrives via pressure from the household cold water line that has to be provided to the rear of your fridge. Two possible solutions:
1. The filter in the upper right of the refrigeration (not the freezer) is clogged by normal minerals, etc. It should be changed at least every year, unless you have major sediment in your household water lines.
2.) The amount of water being delivered to the rear of the refigeratior is being restricted somehow. Trace from the connection on the back of the fridge to see where the water line (either thin plastic line or a small, flexible copper pipe) travels to a cold water line in the house. Look for kinks in the pipe and also look for any shutoff valves that are turned almost closed.
Mar 13, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
LG LFD25860 Logo
94 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
