Question about Whirlpool Dryers
Whirlpool dryer model ler4634eq2 runs, but will not heat
  • Whirlpool Master
  • 1,902 Answers
Hello
No heat in your whirlpool is caused when the thermal fuse goes bad and needs replacement. As everything else is working so the problem is with the fuse which is located on the blower wheel housing inside the back panel and to replace you'll have to open it. Please get back to me if you have any other questions.
Kevin
Posted on Nov 11, 2010
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it.
Hope this will help you
Feb 27, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not start whirlpool model #LER4634EQ2 SERIAL #MK0296464 TYPE#D433-ELE-2406028-FM54
It might be the fuse.3727d80.jpg Be sure you do a bit of cleaning before you replace the fuse or it might just blow again.a611954.jpgca0922b.jpg Look for lint. I looked up your model. I once did a write up about what goes wrong, how to get into the machine, a training manual and videos. HERE
Bonus stuff
Helpful? Rate please.
Sep 19, 2010 | Whirlpool Dryers
Dryer was running. Put in a new load and it won't turn on now. I checked the fuse box, it was good. any idea. model # LER4634EQ2
Thermal fuse. Pull rear panel off and theres a little white fuse with two blue wires on it. Its got one quarter inch screw. You can tie the two wires together and check if that is your problem - but I recommend replacing the fuse. Good luck...
Nov 16, 2009 | Whirlpool LER4634J Electric Dryer
I have a whirlpool LER4634EQ2 electric dryer and I just replaced the heating element and will still blow no heat.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
The thermostat/thermistor should be located in the air duct where the heating coil is located.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 02, 2009 | Whirlpool LEQ9858L Electric Dryer
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
Cloths not drying
Hey jeff, you can test a heating element for continuity with an ohm meter, good luck.
Mar 23, 2009 | Dryers
Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Mar 07, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
477 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
