Question about Denon DRA-565RD
Denon DRA-565RD won't power up. Where is the fuse located and what kind of fuse do I need to get?
SOURCE: denon dra 1025ra seems to
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
Posted on Jul 09, 2008
  • 7 Answers
SOURCE: MY DENON DRA-435 A RECEIVER
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Posted on Jul 23, 2008
  • 119 Answers
SOURCE: denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Posted on Mar 02, 2009
SOURCE: Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Posted on Jan 06, 2010
I have a denon dra-697ci power is plugged in but face does not have any lights nor does the power switch have any both fuses are okay any sugestions would be greatly appreciated
Most likely, you Denon has a condition known as DC Offset(meaning a damaged amplifier which requires a major repair) The other issue, may be a microprocessor IC, a computer within you Denon) that has had some issue, causing it to not power up. Try a Factory Reset first. The procedure is found in you owners manual under, Reset, Factory Reset, or Rest to original setting, as it came from the factory..If you need further assistance, please contact me at my my website at audioserviceclinic.com. Thank you.
Jan 14, 2014 | Denon DRA-697CI
I am a comercial electrician. My company installed 2 Denon recievers on a job and 1 has gone dead. There is power to the unit but no power to the recepticals on the back. Is there a reset or a fuse?
Are they "switched" recepticles? I believe they are but, the picture I'm looking at is too small. This is the manual for the unit;
http://usa.denon.com/DocumentMaster/US/DRA-397-OM-E_103.pdf
This is the link:
http://usa.denon.com/US/Product/Pages/Product-Detail.aspx?Catid=3ae4a4d9-ae28-4018-bb66-611b99e1320d&SubId=0&ProductId=8e00bd6c-d3e2-466f-b5a0-c7ebe94e0bd9
Just glancing at the manual, of course it doesn't mention a fuse but, I'm quite syre if you pull off the cover, there is a fuse or two on the circuit board. Anyway, I wasn't trying to be smart about the "switched receticles and, you probably already knew but, if they are switched recepticles, they will only work when the unit is turned on.
Jun 06, 2011 | Denon DRA-397
I have a Denon receiver dra 545a that won't power on... how costly might it be to repair
Sounds like the power supply went out. Check inside to see if a fuse is blown. Replace it once (with the exact rating) and if it blows a second time, then you have something shorting out and can be costly to repair. DO NOT replace the fuse with a higher rating for it might cause a fire.
Oct 31, 2010 | Denon DRA-397
Will not power up.voltage on both posts behind switch.no voltage on secondary of transformer. anyone seen this before???
There should be a fuse between the switch and the primary. Have you verified that there is voltage on the primary or checked the continuity of the mains fuse?
Feb 09, 2010 | Denon DRA-565RD
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Dec 16, 2008 | Denon DRA-397
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
Right channel not working
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
