Cooker hood smeg opera 100cm what height should it be? and do i have to keep the chimney part on it?
    Novelist:
    Champion:
  • 230 Answers
Please check with your local building code for this information. Most inspectors will gladly answer your questions if you call them. You may be able to find the codes on local government web site too.
Check the manufactures recommendations as well. They should be in the box that the unit came in.
Posted on Jun 17, 2008
No instructions nor fixings with cooker hood. How do we attatch it? How do we get hold of fixings as staff at wicks were useless. Cookerhood EFC90950X zanussi
you will have to place a straight edge on the top on the hood near the exhaust pipe then mesure from the floor to the bottom of the straight edge, that will give you depth then here is the demisons you have to build the box in. And if you don't have the power there you need to get a contrator or do it yourselfer to install it four you.
Price Range:£342 — £2,084 Average Price:£673 —— Colour body Stainless Steel. Body Material Stainless Steel. Colour chimney Stainless Steel. Typology Built-In. Motor location Integrated Motor. Operating Mode Convertible. Connection Rating (W) 225. Voltage (V) 230. Frequency (Hz) 50. Approval certificates IMQ. Length electrical supply cord (cm) 190. Height of the chimney (mm) 815/1970. Height of product, without chimney (mm) 815. Dimensions of the product, with chimney (if exists) (mm) 815-1970X898X490. Dimensions of the packed product...
Aug 21, 2009 | Electrolux Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Kitchen Ranges
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
