Question about Kingston 1 GB microSD Card with USB 20 microSD Card Reader FCRMRB+SDC1GBKR (Black) Drive Case
I have windows xp but when I Insert the usb drive with the memory card nothing happens .everything else worked ok ,taking pictures using adapter to download at photo shop,would appreciate your assistance.
  • Kingston Master
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then return and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
also you might need to do this
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Posted on Nov 13, 2013
My computer no longer recognizes my nikon coolpix L5.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 19, 2012 | Nikon COOLPIX L5 Digital Camera
Micro sdhc
are you sure that the mobilemate micro usb adapter is working??
is it able to detect other memory cards?
Dec 27, 2007 | Computers & Internet
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Apr 08, 2010 | HP Photosmart M547 Digital Camera
I have a windows xp and a lexar microsd 4gb adapter
Hi If your card is SDHC version is possible that you card adapter doesn't support it, you have to try another one.
Oct 19, 2009 | SanDisk 2GB microSD Memory Card
I have a SanDisk 4GB MicroSD (TransFlash) Memory Card, bought to use with a Nokia 3109 mobile pone. The phone indicates that the disk is unformatted [and doesn't format it]. My laptop [Windows XP...
Sounds like a defective card. Some phones only take up to 2 gigs, and will not format anything larger. Try the card on another phone or computer.
Jul 25, 2009 | Electronics - Others
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Inserting SanDisk Cruzer in USB, REBOOTS the Computer instantly
Not sure if this is the problem, but I just found out that in some BIOS menus, there are 3 options for your USB controller...Enable...Disable...No Boot.
If you know how to get to your BIOS, it's worth a shot to make sure it is set to "No Boot" if it is an option.
Oct 09, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB imation drive 1 gig
Usb is infected with virus and if u cant re-write it with binary languange just buy new
Oct 23, 2007 | Electronics - Others
Kingston 1 GB microSD Card with USB 20 microSD Card Reader FCRMRB+SDC1GBKR (Black) Drive Case Logo
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
