Question about Asko W6221 Front Load Washer
Asko 6221 washer won't drain, now won't fill either
Hi My washer was bought used and hasn't worked right since I got it. The drain doesn't work and makes a gravelly sound, but the pin trap is clear. A repairman replaced the drain pump, but it still doesn't drain and still makes that noise. Only now it doesn't fill, either! I manually drained it. so the drum is empty, but the door doesn't open. It does rotate back and forth , as in a wash cycle, but instead of filling it just hums. Any ideas?
Jim
  • 2 more comments
  • griff45 Jun 20, 2008
    Still getting nowhere on my Asko 6221 washer. The drainlines are clear, checked by the repairman, and the pump was replaced, but still not draining and still making that sound. Anyone?
  • griff45 Jun 25, 2008
    In answer to Micromaster, the water doesn't drain out at all. The drain for the hose is about 35 inches high. Also, now it doesn't fill either. I was wondering if this is a problem with the machine's fill valve or an circuit board.
  • griff45 Jun 26, 2008
    A question for Hematraj : The Asko 6221 appears to have several circuit boards, One called the Timer Control Assembly, Another called Control Unit wm33/44a. The second one is the large board, the first one seems to be part of the timer knob, but has a circuit panel, too. As these are expensive, I want to be sure which one to order. Thanks for being very helpful!
    Jim
    My asko washer, 6221 has a gravelly sound when it tries to drain. The pump was replaced by a repairman, but it still makes that sound and doesn't drain. Now the washer won't fill, either. I hear the sound of something trying, but then just a hum and no water. The valve is on and there is water to the machine. One expert suggested it was faulty control board that was to blame, but which one is it? These boards are expensive so I want to get the right one!
    Thanks for any help.
    Jim
    Genius:
  • 1,011 Answers
Dear Sir,
Although all brands are different in design, the basic concept is the same. Water comes in at the top, and goes out at the bottom. A pump forces the water to go in a particular direction. When a machine won't drain, there are several things to consider:
  • Is the drain hose kinked?
  • Does the lid switch click when closing? (see video below)
  • Something in the pump or hoses? Check the hose coming down from the tub for socks, rags, etc.
  • Bad wigwag?
  • Broken belt? Loose belt?
  • Current to motor? (Use voltmeter to check)
Never seal off a washer drain because your drain is sluggish. Have it cleaned professionally. Sealing off a washer hose will cause pump failure in a short time, not to mention wear and tear on the clutch and basket drive parts. A siphon break kit is available for those with difficult drains for $15.95.
Thanks
Good Luck
"Don't forget to rate the Solution"
Posted on Jun 26, 2008
    Genius:
  • 2,028 Answers
To be perfectly honest with you, there is a multitude of things that could cause this, from a clog to bad circuit board to an intermittent problem with the pump. It can get costly to narrow down the exact problem, and may be cheaper and definitely easier to buy another used washing machine. You can get a used washing machine fairly cheap, and it beats the headaches you going to have with this one. Try buying from a place that sells refurbished versus an individual, these places will usually work with you if there is a problem.
  • 1,879 Answers
Greetings,
The washer is bound for service.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Master:
  • 638 Answers
U will hve to get ur control card repaired.the problems u shared with us arises due to faulty circuit control card.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem...
Posted on Jun 20, 2008
  • 4,889 Answers
Check the lid switch.The bracket holding the switch may be broken or the switch may be faulty. Check it and report so thatwe can follow up..
  • eagle338
    eagle338 Jun 25, 2008
    Hi did you check the lid switch?
    Brigadier General:
  • 3,614 Answers
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
  • Posted on Jun 20, 2008
    • micromaster
      micromaster Jun 25, 2008
      if you were working now inside the unit and there a lot of space to see around the parts inside, it is better that you check also the water inlet valve on the washer, it was located on the lower left corner possibly on your unit..
      let me know..
      Genius:
    • 3,422 Answers
    If it won’t drain check these.
    If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
    To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
    Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
    If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
    It doesn't spin or pump
    If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
    It pumps, but the water returns
    Posted on Jun 17, 2008
    • 4,472 Answers
    How long did it work for after the repair man replaced the drain pump?
    Thanks,
    Lee
    • 2 more comments
    • Lee A.
      Lee A. Jun 17, 2008
      Sounds like you might need to replace your circuit Control card.
      This is most likely the case.Since you cleaned out the pin trap this is the only other solution. I would contact the repair man I dont believe he fixed the correct problem.
      Hope that helps,
      Lee
    • Lee A.
      Lee A. Jun 18, 2008
      If you need any further assistance please let me know.
      Thanks,
      Lee
    • Lee A.
      Lee A. Jun 19, 2008
      Still hoping to hear back. Let me know how it went. If I don't hear back I will assume all is well. If you found this helpful and have a moment you can accept and rate the solution accordingly.
      Thanks again,
      Lee
    • Lee A.
      Lee A. Jun 26, 2008
      I am not convinced it is a "control card" at this point.
      Thanks,
      Lee
    I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
    F2 code is water level to high
    Washer Error Codes
    Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
    Asko Washer Error Codes
    • F1--Water supply/low water fill.
    o 1. Check water supply to machine.
    o 2. Replace water inlet valve.
    • F2--Water level too high.
    o 1. Plugged/Bad water pump.
    o 2. Faulty water valve.
    Sep 19, 2014 | Washing Machines
    My ASKO W6222 won't drain
    Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
    Jun 20, 2012 | Asko W6222 Top Load Washer
    Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
    A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
    The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
    There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
    To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
    Washing Machine Does Not Fill
    If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
    Washer Does Not Spin
    If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
    asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
    Clothes Are Wet After Spin Cycle
    If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
    1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
    2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
    3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
    Oct 27, 2011 | Washing Machines
    Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Aug 13, 2011 | Asko W6221 Front Load Washer
    For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
    Hi
    If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
    If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
    Please check the link to get some more idea:-
    http://www.washerhelp.co.uk/diy-repair-help_8.html
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting fixya.com
    Jul 07, 2011 | Washing Machines
    I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
    My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
    Oct 19, 2009 | Asko Washing Machines
    Asko w6021 still not working
    check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
    Mar 31, 2008 | Asko W6021 Front Load Washer
    W 6221 stop working
    Suggestion: Plug off the wall; open up behind. Take a good look to see if all the electrical connections are fitted well into their respective places, and that nothing has come loose. The fit should be tight, or it will just come off when the machine vibrates...
    Nov 24, 2007 | Asko W6221 Front Load Washer
    W 6221 power indicator light is out
    take off the top it could be a bulb gone
    Oct 02, 2007 | Asko W6221 Front Load Washer
    Asko W6221 Front Load Washer Logo
    427 people viewed this question
    Top Asko Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
    Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
