Question about Frigidaire Dryers
I have a frigidaire clothes dryer, model number FSEC747GES1. it turns on but after about 15 minutes the top back corner of the unit gets extremely hot. It also seems to work intermittently. Not sure if I need to be concerned of a fire hazard in my home. I opened the unit and vacuumed and lightly brushed out any lint or pet hair. All the wires and contacts were cleaned of lint. The rear and inner screens were cleaned out. Your advice would be greatly appreciated!
watugot
  • 290 Answers
SOURCE: dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Posted on Nov 24, 2007
danromarris
  • 101 Answers
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Posted on Mar 25, 2009
SOURCE: My Frigidaire dryer model FEQ332ES gets very hot
my dryer gets very hot on the outside what should i do
Posted on Aug 18, 2009
mmayton
  • 135 Answers
SOURCE: code f40 cleaned out lint area with a brush and
Try this web site I used it to repair my dryer.
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Hope this helps
Posted on Dec 10, 2009
Why is my Frigidaire dryer model #FER86600ES0 getting extremely hot on the top and back?
Good afternoon friend, thanks for the post!
I see from your post that your Frigidaire dryer is getting extremely hot on the top and back. Have you checked to make sure that it is getting proper ventilation? I would verify nothing is blocking your dryer from ventilating which could be causing the appliance to heat up. If it continues to heat up I would reach out to a technician to come diagnose and repair your dryer. I hope this is helpful. -Matt
Jul 31, 2014 | Frigidaire Dryers
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire clothes dryer, model number FSEC747GES1. it turns on but does not get hot, just cold air. wondering if it is the heating element and if so what part number it is, aprox. the cost and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Dryers
Where can i find the thermal fuse location on a frigidaire clothes dryer?
Open the top lid and look in the back right corner.
With a model number I can be more specific.
Jul 05, 2009 | Frigidaire Dryers
My Fridigidaire gasdryer will heat up for the first part of cycle
It sounds like the coil valves are not continuing to open.
If you can get the dryer open, (unit UNPLUGGED of course) you will see that the gas valve has two black cylinders on top of it with wires coming out. Electricity magnetizes these and that magnet is what opens the gas valve so that the dryer can heat. When they get old, the electricity starts to heat them up, and they stop working. You end up with a dryer that will heat up for the first 2 minutes of a load, and then stop heating.
The coils are very easy to replace, and are usually held in with a small bent metal plate and two phillips screws. Removing this plate and the coils doesn't interfere with the gas plumbing, but if turning the gas off makes you feel better, go ahead.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-coil+valve-%3d%3di3479&PartID=3479
I'm not sure if those are the ones for your model or not, but that is what they will look like. Check the model number on the sticker inside the door to make sure you get the right ones. Be sure to get the kit of 2.
Apr 07, 2009 | Frigidaire Dryers
I have a Frigidaire Electric Dryer FEQ1452HS 5.8cycls (front loader). Purchased in December 2008. The dryer has never dried the clothes very well, but now I have a bigger problem. When dryer is turned, it...
Sounds as if something has the tub locked. Remove the top of dryer so you can get look at the tub. You may have to remove the tub to locate the problem.
Frigidaire dryer problem
The vent duct length's sound fine.
Have you confirmed that the heater element is working? You don't mention whether the unit get's hot.
If it get's hot, then suspect the thermostat, or the overtemp stat.
Also, be suspect that users are overloading the dryer.
Also make sure that you feel a strong blast of hot air discharging at the vent end, with the washer/dryer in place.
Check that the vent grills inside of the dryer are clear.
Reply back and I can help you further.
Feb 03, 2009 | Frigidaire Dryers
Dryer gets hot to the touch
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Dryers Logo
59 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
