Question about HP Color Laserjet 3550 Printer
The error message 50.9 comes up..it's a fuser error..i took the fuser out in the back and put it back in..still having a problem
  • HP Master
  • 7,733 Answers
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart and...
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
Oct 25, 2010 | HP LaserJet P3005d Printer
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Dec 26, 2009 | Office Equipment & Supplies
Hp 2605n Fuser error 50.7
50.7 means that the photo sensor ps6 detected no movement
Open the side of the printer power on the printer and check if the fuser motor moves forward and back. If it does the problem is with the movement sensor or feedback circuitry. If it doesn't its the motor, gear system jamming, motor driver or power supply pcb.
Aug 11, 2009 | HP Color LaserJet 2600n Printer
Error Message C 50 on a Minolta 1031F copier
Fuser code, to reset turn of the machine, if it comes back on the fusing unit the (Hot part) needs to be replaced Upper fuser roller (UFR) carries the lamp. Check the thermistor and thermostat also before replacing UFR
Jul 28, 2009 | Minolta Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
102 people viewed this question
Seeker5211
Seeker5211
