Question about Car Audio & Video
What is Bluetooth pairing code for my Pyle head unit? (0000,9999,1234 doesn't work)
NeTTeKco
  • 72 Answers
SOURCE: bluetoothe connection to sony erriccson c902
check your manuel for the unit their will be a code that you have to put in to finish the connection you said you tried 1234 and 0000 but that might not be the right code you can also go into the settings of the device and check all that to see if their is a option in the settings
Posted on Aug 07, 2009
  • 504 Answers
SOURCE: default pin for pairing bluetooth
This varies unit to unit. Most generic codes are "0000" or sometimes, "1234", but it could be different. Which GPS device do you have?
Posted on Feb 23, 2008
SOURCE: pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Posted on Mar 19, 2009
SOURCE: Old phone would pair with Clarion VRX785BT's bluetooth
WHEN TALKING ON BLUETOOTH ON VRX785BT VOICES ARE BREAKING UP AND SOUND LIKE UNDER WATER.
Posted on Jun 12, 2010
SOURCE: i cant find my pairing code for my Samsung WEP450 ...
your code:- 0000 just try
Posted on Oct 30, 2010
Left speaker in my 1998 chevy s10 fades out then dies
What have you tried?
Is this an aftermarket sound system?
It could be a fault in the head unit, the cables or the speaker itself.
Assuming that its and aftermarket head unit using original wires this is what I would do:
Remove the head unit to gain access the wiring behind.
Most units have the wiring colour coded and a generally in pairs for +ve and -ve, some even have them label LR (Left Rear) RR (Right Rear) LF (Left Front) RF (Right Front).
The wires are commonly joined to the existing speaker wires by insulated electrical "connectors" that simply pull apart, though only pull on the connector NOT the wire.
Half-way jobs are just the bared wired "twisted" around the joining wire and wrapped in electrical tape.
Ensure all the connectors are still in tact and
Test after removing each pair of speaker wire to which speaker is disconnected.
When you determine which wire is for which, switch the non-working left speaker over with a working one and test to see if the speaker still fades.
1. If it does not fade then your problem is the head unit - I would replace it.
2. If it does then the problem is in the speaker or the wiring.
Remove the speaker and swap with one of your working speakers.
A. If it still fades then the problem is in your wiring and you will need to run new wires.
B. If it does not fade then the problem is simply your speaker.
Hope that helps.
Apr 09, 2014 | Pyle Car Audio & Video
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
Want to know the steps on pairing the samsang woo 200 hands free bluetooth to my htc inspiree
First, Switch off your bluetooth hands free.
Now, press and hold the multifunction button for approx. 8 seconds till blue light appears.
Now, in your inspire, go to settings, "Wireless and network", Bluetooth. Turn on bluetooth and click scan device. It will show your bluetooth headset. Click on its name. It will ask for pairing code. Enter "0000".
You are done
Jun 07, 2011 | Cell Phones
I have an orange amsterdam phone trying to pair with bluetooth and it asks me for an activation code. I have never set one and the book doesn't tell me what the factory setting is
Pairing is a two part activity. On the device you are trying to pair with, you will need to set it to search for a bluetooth device to pair with. On that device, it should give you an activation code.
For example, when pairing with my car, I go into the menu, phone, and "pair". It tells me the activation code is 0000 (pretty common one, so you may want to try it). I put this in, and the phone pairs with the car.
May 26, 2011 | Orange Cell Phones
Can not pair
Try pairing using the following instructions:
How to Pair the Plantronics Explorer 230
If that doesn't work, the unit is most likely defective. You can return to Plantronics if less than a year old for a replacement.
Good Luck from Headsets Direct!
May 18, 2011 | Plantronics Explorer 230 Bluetooth Headset
The blue and red light doesn't. Come on at all
First, make sure to charge the unit for a few hours. Next, try pairing with the following link:
How to Pair Plantronics Voyager Pro Bluetooth Headset
If it still doesn't enter pairing mode, the unit is defective and needs to be replaced. It comes with a 12 month warranty. Contact your supplier to receive a replacement.
Apr 27, 2011 | Plantronics Voyager PRO Bluetooth Headset
I need to know how to hook up my pyle pla4278 4 ch 2000watt bridgeable mosfet amplifier
Hi, I assume you are powering regular speakers in the car, right?
The amp needs a power cable from the fuse box or battery.
This cable should be about 6 gage and should have a fuse of about 150 amps.
You will need a ground cable, also 6 gage and connect it tightly to the chassis under the dash.
Disconnect all speaker wires from the head unit, and use a pair of RCA cables to connect the head unit preamp outputs to the amplifier.
Also from the head unit, connect the blue wire to the "turn on" terminal of the amplifier.
Finally, connect your speaker wires to the amplifier.
Your speakers should be rated for at least 500 Watts, or you will blow them with this amp.
Please let me know if you have questions and thanks for using FixYa.
Jan 12, 2011 | Pyle PLA4278 Car Amp
Hi, my problem is with my nokia bh-214 headset.. when i try to connect it asks for a passcode.. i didnt get on with the unit and have tried the recomended codes like 0000, 1111, 9999, 1234, none of...
when you are pairing the head set and phone make sure the blue light is flashing on the head set witch the blue tooth put the blue tooth on the phone when asked put 0000 they should pair
the head set has to be charged to us it
Sep 07, 2010 | Nokia BH-214 Bluetooth Stereo Headset
I have a Kenwood DNX7100 car stereo with bluetooth connection capability. The unit lost information on my Samsung U540 integration. Manual suggests hitting "Select" under the Setup Menu but this button...
First of all do you have a bluetooth kit for your head unit? if so ensure it is plugged in correctly. if it is, then you need to activate bluetooth on your phone and make it visible to other devices, once this is done search from the phone for the bluetooth on the head unit. It should read BT100 or similar. Once it has found it all you need to do is pair them normally using the code 1234.
Hope this helps
Jan 21, 2009 | Kenwood DNX7100 Car Video Player
Car Audio & Video Logo
224 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
