I have an LG WM1620FD intellowasher washing machine. Yesterday it would wash but wasn't spinning and when we were setting it to drain automatically, it would come up with an OE code meaning the pump or something was blocked. Today, I took it apart, took the pump out and in one of the impellers was a 20 pence piece. I took that out and have put the bloody thing back together again. Now when we go to put it on spin, it locks the door and we get this funny noise. I'm pretty sure that I put it back together as it was so some help would be very much appreciated. Thanks
Washing machine won't drain
Check the condition of the drain pump, replace if necessary as one cannot repair them.
Aug 30, 2014 | LG Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
LG Intellowasher 7kg WD-1255FHB not draining properly
try draining to a different place . my system does not drain into something that can get plugged with leaves
Nov 01, 2017 | LG Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
My washing machine is not spinning anymore
Do not think this is the problem. Make sure pumping out properly,,Could also be motor brushes if its an older machine...
Nov 10, 2009 | Washing Machines
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
