My i symphony M110 unit is in standby mode and I can't seem to turn it on or off. Can you help?
  • 6,993 Answers
First, remove the
i-symphony M110 from the wall plug, connect it back in and try again. If that doesn't solve the problem, then it means your i-symphony M110 is having a power related problem.
Your
i-symphony M110 is having a power problem. One or more component(s) on the power board of your i-symphony M110 is defective, that's why its not turning on.
This problem may have occurred as a result of power surge or excess power entering into the unit or irregular power supply.
If you know about electronic repairs, get a meter, use a screwdriver to open the
i-symphony M110 so that you can gain access to the power board. Use the meter to read the power board and replace any bad component detected.
Once this is done, your
i-symphony M110 will stay on and function normally again.
Good luck.
Posted on Nov 11, 2010
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Symphony mobile phone security code
China Mobile Maximus, Symphony, Bluetooth, Birds, Alcatel, Sigmatel, Carboonn, GFive
-Default user code : 1122, 3344, 1234, 5678
-Engineer mode : *#110*01#
-Factory mode : *#987#
-Enable COM port : *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
-Restore factory settings : *#987*99#
-LCD contrast : *#369#
-Software version : *#800#
-Software version : *#900#
-Set default language : *#0000# Send
-Set English language : *#0044# Send
-Set English language (new firmware) : *#001# Send
Sep 19, 2012 | Cell Phones
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
I appear to be locked out of sending and receiving messages in the message section create and inbox is ghosted out, my samsung M110
Check out this link below to download a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-M110-_E
Send a text message from page 20 in your manual:
1. In Idle mode, press [Left].
2. Enter the message text and
press [OK].
3. Select an empty location.
4. Enter a destination number
and press <OK>.
5. Press <Send> to send the
message.
View a text message from page 21 in your manual:
<Menu> and select
Messages → Text
messages → Inbox.
2. Select a text message.
From page 5 in your manual:
To access Menu mode, press <Menu> in Idle mode.
Option 5 Messages
7 Settings
Option 9 Phone settings
10 Reset settings
If all else fails you can contact Samsung at 1-800-726-7864.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung M110 Solid Cell Phone
Kenwood KDC-138 Standby Question
Standby mode does not completely power down the unit it jsut does not draw as much power as when the unit is on. Also, depending on the unit, it might start back up faster in standby then from power off. You can select to have certain things displayed while in standby mode. Here is what can be selected for this unit:
Standby: displays CD loaded indicator, "STBY" indicator, and clock (when selected)
Hope this was helpful.
Oct 29, 2008 | Kenwood KDC-138 FM / AM Receiver
Earlier; Fisher stacker type unit. stuck in Standby. mode
Hi jamz.
I see this is a pretty ancient posting so you've probably fixed it or given up by now.
I also own a CA-350 Amp which I purchased many years ago here in Auckland NZ.
I've recently had it in bits to fix so if you're still looking for a solution I may be able to offer you some help.
If so, you can contact me at martymarvel@hotmail.com
Oct 25, 2007 | Audio Players & Recorders
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
79 people viewed this question
 Grubhead
Grubhead
