Question about Powerware PowerRite Plus UPS System
UPS reset Why do i have to reset my UPS after each power outage? This happens to mysmall UPS as well as the 6.5 kva. Thank you
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
You should not have to reset the board. Now if your UPS turned off because the power was off for awhile then yea you have to reset. Otherwise you have weak batteries
Posted on Sep 29, 2011
  • 114 Answers
Probably u have a board problem, and the repair can be really expensive.
good luck
Posted on Jul 01, 2008
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
We have a cyber power UPS unit # 425VA connected to our garage rollup doors at my building. Whenever we do the monthly generator transfer testing, the unit needs to be reset so that the doors will operate...
Steve,
Sounds like the batteries in that UPS aren't supporting the draw for the amount of time that the transfer is happening... How long is the transfer to generator? Is that UPS tied to the generator? If not, you should consider doing that, in most cases UPS's work in the interim (between power off and generator on). You might also want to consider a bigger UPS if neither of those options is possible.
Depending on how often you do these 'tests' you may also want to test the batteries in the UPS to see if they need to be replaced.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 26, 2013 | CyberPower Computers & Internet
Have (2) 7 kVA's & (1) 18 kVA Best. Need fans for all 3. What is the P/N and the cost?
Please Call me at Gruber Power Services tech support. It's free tech support. Ask for Eric
Aug 08, 2011 | Powerware FerrUPS 5.3KVA (fj340aa0a0a0a0a)...
Ups 6 KVA power ware 9120 indicate the problem of (charger failure) ,please provide circiut diagrame of relevant UPS or help to point out the particulare section of circuit with component numbers in...
Here is the 9120 documentation page but Eaton generally does not publish circuit diagrams for smaller UPSs like this. Some people may be technical enough to take a UPS apart but most aren't and it can be very dangerous. I suggest you contact the Eaton hardware support forum.
Jul 15, 2011 | Powerware 9120 UPS System
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
My ups is switching off itself immediately the mains goes off.the battery is okay with 13v.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and enviromental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only a float voltage and a true indication of the battery voltage needs the batteries to be tested under a load. there maybe one battery that is faulty and causing the whole battery system to fail.
These lower powered and cheaper KVA type UPS are switch over types (when the mains fail, the UPS switches over to the inverter in milli-seconds to supply mains power). It is a possibility the inverter circuit is faulty and when the mains power fails the inverter does not switch over.
The true UPS type are usually the higher KVA units (over 1500 KVA units) that converts mains power continuously via the inverter circuit. The mains power charges the batteries and the inverter drawing power from continuously from the batteries (therefore there is no switch over time lag from the mains to the battery.
Sep 25, 2009 | MGE Pulsar Ellipse 800 (89363) UPS System
Computer resets with Power cuts not always although UPS supplied
ups may not be true on line, type so sometimes when power outage happens there can be a very small break in supply. this can cause load items to shut down
get good quality on line ups.
Jun 02, 2009 | Computers & Internet
Powerware PowerRite Plus UPS System Logo
1,303 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
