Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
In the middle of self cleaning of jet air single wall oven model W188-C the door locked. we have turned off the unit, tried to reset it tried to restart the cleaning.. the door is locked and will not allow any feature to be used
  • Jenn-Air Master
  • 3,053 Answers
Hello, lwseaman
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Door won't unlock after self clean
Try turning the breaker off for a few minutes, If that doesn't work try restarting the self clean mode and canceling after it starts. If that fails list a brand and model number with the problem.
Mar 02, 2008 | Ovens
Jenn-Air Oven - Model W46 - Door Lock Lever came loose
you have to turn the breaker off then pull the oven out from the wall till you can get the top off the motor is at the front you will see how it goes
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
46 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
