Question about Mackie SWA1801 Subwoofer
I am looking at 2 used Mackie SWA1801 subs,sn's (21)HT100096&(21)HT10099.Were these made by RCF or in China?
3 Suggested Answers
SOURCE: MACKIE SWA1801--Sound quality is not same
First, Try the "defective" woofer in the cabinet that works well to be sure the woofer is OK.
If the woofer sounds good in the other cab, look to the power amplifier board : you have to test 2 fuses and 2 transistors witch are connected to the fuses : a defective transistor let your subwoofer work fine to half power, but distortion appear if you push away...
Posted on Oct 27, 2007
SOURCE: round bass
make sure you are useing a balanced output from your mixer not phono
Posted on Jun 13, 2008
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
Components Q12 & Q13 (2N 3906) PNP transistors fried. Would there be anything else blown?
It is sad your having a problem with Q12 and Q13, check the regulator
that supply voltage on the transistor 's your referring to.
Q13= 2SA1478 for Mackie SWA1501 Active Subwoofer
the supply is about +15V and -15V
Aug 20, 2012 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Jul 01, 2010 | Mackie SWA1801 Subwoofer
How do you get to the ac fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
May 13, 2010 | Mackie SWA1801 Subwoofer
How to change the hf unit?
a new diaphragm can be fitted into the original driver and the speaker will be like brand new. first you must determine if you have the older RCF version (M44TI) or the newer Mackie versions (0008093). There is only one RCF diaphragm that will work for this repair and they are scarce. There are both authentic and aftermarket Mackie diaphragm options and both work very well.
cathy@speakerex.com
Jun 15, 2009 | Mackie SRM-450 System
Swa 1801 mackie blown capacitor
Took alot of finding but you can get them from Digi-key
Sep 16, 2008 | Mackie SWA1801 Subwoofer
No sound
Willing to bet you've blown the amp, or fused the coil. I've had it happen twice, apparently when running off a power source that apparently couldn't handle the load. Hope it's under warranty - if so Loud Technologies (deals with all Mackies warranty stuff) should be able to replace the unit. Otherwise, you'll need to take it in to a service department and have it checked out.
Good luck, you'll have to arm wrestle with them to get them to replace it.
Jun 12, 2008 | Mackie SWA1801 Subwoofer
Round bass
get a bass amplifier and connect to the subwoofer.
Apr 14, 2008 | Mackie SWA1501 Subwoofer
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
56 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
