Question about Maytag MAH21PD Front Load Washer
We have a model MAH22PDBWW0 showing error code F20. How do I reset the machine?
SOURCE: HE3t f20 error
We had the same problem with a new machine. We washed one load successfully and the second time we got the F20 code. Sears came out and determined it was a bad valve. They had to then schedule another service call to fix it.
The new part was shipped to our house. The repairman showed me the old valve with some black debris on it, saying that our lines were dirty and that contributed to the problem, but its hard to understand how one use of the machine would clog a good valve. Anyway, with the new valve the machine works fine.
Posted on Oct 30, 2007
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Posted on Jan 17, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
  • 572 Answers
SOURCE: Duet Steam washer, F20 error. help
make sure pump is clear. open toe panel and access pump.
Posted on Feb 12, 2010
  • 662 Answers
SOURCE: Error code F20
http://www.fixya.com/support/r3608632-f20_error_code
Advice by jsrock516
Posted on Jun 04, 2010
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What can I do to reset may washing machine showing an error word of f20
F20 is a water inlet problem not sufficient water supply. Select power/cancel twice to cancel cycle unplug washer or disconnect power
Check both hot and cold are open completely
All screens a
Jul 14, 2015 | Maytag Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
The display is reading F20 Out of Order. I know that behind the frot panel, there is a way to reset the machine, I just can't remember what does it.
sadly many times when we learn something once we should write it down and put with owners manual . try unplugging it for a few minutes .
Dec 07, 2017 | Maytag Washing Machines
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
F20 error
F20 is a door lock problem. Try resetting the breaker. if the code comes back replace the door lock.
The first thing I would check is the door lock switches and the wire harness.
Here are the break down diagrams for the Frigidaire range Model PLES389ECB
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag MAH21PD Front Load Washer Logo
282 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
