Ricoh gx3050sfn: has been sitting unused for 2 months. Put all new cartridges in. Hooked up as network printer. Computer link to printer works fine. Printer barely prints. So light as to be unreadable. Same issue for copy and for print. Tried using maintenance functions, but only using up ink, nothing else happening. Cyan cartridge being used up most and very quickly even though nothing can be read. Any suggestions??
  • btannenbaum Nov 12, 2010
    Thank you, Selk, for the very prompt reply. I will try that and see if that solves my problem. Certainly sounds logical.
    Again, thanks.
    Bruce
  • btannenbaum Nov 17, 2010
    Thanks for the response, Willl see if a printer tech can truly clean the print heads or whether they need to be replaced before deciding on total repair or replace. Thanks for your advice.
  • 32,281 Answers
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Posted on Nov 14, 2010
  • 734 Answers
Hi There,
When printers sit unused for a while, the printer heads invariably dry up with ink inside them. I recommend you have a printer servicing technician stop by and do a proper printhead cleaning for you. It's my belief this will resolve your issue.
Regards,
Selk
Posted on Nov 11, 2010
Epson WF 7010 sitting for several months -- wont print black -- colors ok -- print did a firmware update whne put back in service
Inkjet cartridges dry out and fail when printers sit unused for extended periods of time. The black ink cartridge is probably no longer usable. Updating firmware won't have any effect on the issue.
Dec 31, 2014 | Epson Office Equipment & Supplies
How to install RICOH Aficio 2045eSP to network computer?
do you use a switch or a router on your area, and also may i know the OS that is installed on your PC..
thanks
Aug 06, 2008 | Ricoh Office Equipment & Supplies
How to solve system error s001
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Jan 23, 2013 | Ricoh Gx3050sfn All-in-one Inkjet Printer
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
System error 0990. What to do?
I was told it was a bubble in the line and you would have to turn it off and let it reset 9 or 10 times for the system to work the bubble out.
Sep 16, 2010 | Ricoh GX3050sfn InkJet Printer
How to fixe error(0990) in Richo gx3050sfn
Error 990 is an error that has to do with the ink carridge system. This is a Ricoh defect. If your printer is still under warranty you can call Ricoh and inform them of the error and they should replace it. To try and fix is 50/50. We usually just recommend getting a replacement.
Jan 19, 2010 | Ricoh GX3050sfn InkJet Printer
80 people viewed this question
jasbo
jasbo
