Question about Panasonic Lumix DMC-FZ8 Digital Camera
My Camera's shutter button is insanely hard to push down.
Instead of having a normal 2-click motion (1st is auto focus, second is shutter activation) it goes to auto focus, then no click for the shutter. It still takes the picture but requires about 10x more force to push down than it normally should.
How should I go about fixing this? I could take the camera apart, but am weary about it.
  • codip426 Jun 21, 2008
    Well, it worked, but I can't get the zoom button to sit flush. Any tips on that?
    Problem Solver:
  • 8 Answers
Hello codip426,
I had a similar problem with my FZ7 a few days back after a hectic day of shooting. However, one of my cursor buttons at the back was affected. So this solution may or may not work for you. But try it since opening the camera should be the last(est!) resort.
Take a very very slim steel needle, like the ones used for insulin injectors. They are far slimmer than paper pins or staples and offer a good grip required for this operation. You can find one at a medical store. Ask for insulin pen needles.
Gently, avoiding making scratches, insert it into the space between the shutter and the zoom control lever. Run this needle inside that space around the shutter, 360 degrees. Do it gently and with even force. If you meet any resistance try to dislodge it gently.
The problem that you have usually occurs when the button is out of its housing. The needle trick usually fixes it.
I hope it works for you.
Posted on Jun 17, 2008
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Better Focus
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Better Focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Rely on the LCD Monitor, especially for Telephoto and Macro photography. Due to differences in depth perception, the Viewfinder is not as accurate at the LCD Monitor. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Better Focus
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Focus
Sep 11, 2005 | Toshiba Sora PDR-T30 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
162 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
