Question about OKI C5150n Led Printer
Error code 543 K toner sensor error - OKI C5150n Led Printer
  • chris76641 Nov 12, 2010
    The sensor is missing from the toner cartridge. I need to get a replacement.
    Thanks
    Thanks for your help.
  • OKI Master
  • 1,679 Answers
Seems like you have a bad black toner cartridge or the sensor is dirty.
The sensors are located on the toner cartridge and in the machine where the toner cartridge seats.
The sensors are silver color. Try cleaning the sensors with a Q-Tip ( or ear bud ) and try again.
If it does not work you should replace K (black) toner.
For your future reference, click on the link to resolve other issues related to the printer
Troubleshooting Link
Hope this is helpful.
* Rating and comments are welcome on this solution
Posted on Nov 11, 2010
  • 2 more comments
  • ONE-Touch-Solution
    ONE-Touch-Solution Nov 11, 2010
    I would like to know if you were able to resolve the issue.
    Thanks.
    FixYa Team
    ONE-Touch-Solution Nov 12, 2010
    You are welcome. The replacement will resolve the issue.
    Thank you for contacting FixYa
    Don't miss to rate the solution provided.
    Thanks.
    FixYa Team
    ONE-Touch-Solution Nov 18, 2010
    I would like to know if the solution provided for your issue " error code 543 K toner sensor error
    " is solved ?
    Regards
    FixYa Team
    *Please rate this solution with thumbs up
I received a message "543:
this means that the toner chip on the black cartridge is defective and theres really nothing you can do other then get another black toner to replace it with. some companies do sell the chips but probably easier to return where you bought it and get a new one to replace it. The company ,if reputable shouldnt charge you for another one but just exchange it with a working toner... Please mark as FixYa! if this helped...Get Paid To
Aug 04, 2011 | OKI C5150n Led Printer
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
Toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
May 03, 2009 | OKI C5150n Led Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
543 K: Sensor Error
I had the same problem, after lots of work and fooling around..............Place a piece of white paper in the window where the sensor looks
Jun 18, 2008 | OKI C5200n Laser Printer
Message to order new k immager
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Mar 09, 2008 | OKI C5200n Laser Printer
Toner sensor error
Feb 11, 2008 | OKI C5200n Laser Printer
OKI C5150n Led Printer Logo
593 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
