Question about Acer Monitor
Just bought a new H213H monitor. Video is fine, but the audio is barely audible...volume control is set as high as it will go, and the sound is still way too low. My system is Window XP if that is pertinent to this problem. What to do?
  • sjsampson Nov 11, 2010
    Thanks for the info....I sure wish the sales person had told me what you did. I wouldn't have purchased it!! Nevertheless, thanks for your help.
    That helps....Thanks again.
  • 4,889 Answers
Just so you know, the built in speakers of this monitor are 1 watt each and the total output being 2 watts. That is almost 30 times less than what the lowest desktop speakers' output. Check your system volume too. If its where it should be then thats the max output. People I know who own this monitor, use external speakers as the built-in speakers are not for gamers or musicaholics.
You can check out the specs here
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009157
Posted on Nov 11, 2010
  • eagle338
    eagle338 Nov 11, 2010
    Thats called marketing my friend. The loopholes are always masked. Its a great display nonetheless. 1080p on a monitor for such low cost is a steal! Thanks for using Fixya.
Audio of Hyundai tv set
Some components are getting heated up most probably in the sound section due to high voltage. Either there is a failure of regulated power supply to that are or the IC or other components in the board are defective. This is a case to be handled by a qualified service technician, as the back cover has to be opened.
Aug 19, 2012 | Hyundai Televison & Video
I have no sound out of the front speakers. Mute button is off, speakers work fine. Only have sound (very little) if volume is turned way up.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's
full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume
it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape
Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead'
spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like Tape
Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 10, 2011 | Yamaha RX-V870 Receiver
I have a HK3550 receiver and it was working fine until yesterday when I turn it on I have to turn the volume all the way up just to just barely hear it. Is there a simple fix
Probably just a control out of place.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-HK3550-Receivers-manual/id/386ag412/t/2/
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Apr 22, 2011 | Harman Kardon Audio Players & Recorders
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
Apr 09, 2011 | Onkyo TX-910 Receiver
I have a Kenwood 1060vr and I have no sound what so ever. There is a hissing sound from each speaker but absolutely no sound, doesn't matter the setting
Apr 02, 2011 | Kenwood 1060VR Receiver
The volume is barely audible even with it turned all the way up. I have tried different audio cables. It occurs in different modes also, CD Tuner, etc.
Maybe you have it muted or a Tape Monitor engaged??? Never troubleshoot anything at high volume. If you can't hear it at medium it's effectively noth there. A flip of a misplaced switch would possibly blow your speakers.
Jan 16, 2011 | Optimus STA-3500 Receiver
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
Volume
Did it stop working or has it ever worked before?
Make sure there is a cable running from your computer to the monitor's integrated speakers. It should go from a green 3.5mm output jack at the back of the computer to one the same size in the back of the monitor. If the cable is there and still no sound, double check the connection, make sure they are plugged in securely at both ends. Be sure that headphones are not plugged into the computer at the same time or audio will only come out through the headphones.
Make sure the audio is not muted. There is a mute in possibly 3 places. One spot is the application audio: if you're trying to play from Windows Media Player, make sure the audio is not muted near the slider and that the volume is loud enough to hear.
Second place is the system volume. In the Control Panel, Audio (Start menu, Settings, Control Panel, Audio component) you can check the volume and mute of the system volume.
Third location is the monitor speakers. There may be a way in the monitor's menu to adjust the volume for the speakers. Make sure it is high enough to be audible.
If all of those are unmuted and high, you might try replacing the audio cable. Also reboot the computer with the audio cable plugged in where it should be. (Sometimes high-def digital audio can be quirky). Next try plugging in a pair of headphones into the front of the computer and see if you're getting any sound through there.
Those steps should help you diagnose the problem. If not, just post back with what you found out through these steps.
Nov 25, 2008 | HP Compaq WF1907 Monitor
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Computers & Internet Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
