Question about Ovens
My knmore gas oven does not work. the stove top is fine but the oven does not heat up. I tryed lighting it up manualy but still dont light up..
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 12, 2010
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
48 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
