Question about Konka K2001UM TV
No volume t.v. works great except there is no external volume, the headphones do work when they are plugged in. model is konka 2100um
  • 41 Answers
The speaker inside the tv is deffective... change the speaker..
Posted on Sep 17, 2008
Where is the audio out on rank arena tv model sv-42h1fhd100
my samsung has it on the back 3.5 but it is for external speakers with external amp.plug in headphones very little volume.tv volume will not work when switched to ext.speaker. note this is the way mine works if yours is the same by an adapter with a 3.5 end and 2 rca plugs on the end plug them into the in on the cd player etc.
Feb 24, 2015 | Televison & Video
Where do you plug in the headphones?
You can plug in headphones but you need an adapter. Also, not all headphones will work well with this TV. You should get headphones with in-line volume control. Then connect the headphone 3.5 mm M to a 3.5 mm F to dual RCA (1/4") M/M adapter. An example is http://www.sears.com/shc/s/p_10153_12605_05711931000P?sid=IDx01192011x000001&srccode=cii_17588969&cpncode=22-191604286-2 .
Then use the TV audio menu to turn off the TV speakers and enable the external speakers. Note the TV volume control will not effect the headphone volume.
I hope this helps.
Dec 23, 2011 | Mitsubishi WS-48311 48" Rear Projection...
Hi , Im trying to make my external volume controler work om my Aer 4520. Its a litlle ring that puts volume up and donwn
Ebv65,
External speakers for your laptop are very easy to hook up. They should plug right in to the external speaker outlet on the laptop. Your acer 4520 has a Headphone/speaker/line-out jack with S/PDIF support. First you need to check all your volume levels within the control panel (located in the sounds and devices folder) to make sure they are up. This solve your problem. Thanks for visiting Fixya.com. Have a great day.
techguy21
May 28, 2011 | Acer Aspire 4520-5582 Notebook
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I have a 50" samsung plasma that was working fine now the volume just dissapeared & when i try to adjust the volume it shows the normal volume display with headphone icon in the display & when i...
You would need to replace the headphone socket then and if I am correct it should be mounted to a plug in board. I first need the model number of your Samsung to look up the part number. The model will be on a sticker on the side and will be something like HTP50***/XAA or something like that.
Sep 02, 2010 | Televison & Video
Volume Wheel, Headphone/mike/line in jacks not working
hi, try to install the LaunchManager aplication and touchpad (Synaptics) driver. It is avaiable at acer.co.uk, service & support, select the model, the select windows xp professional x32 as your operational system...
Jul 24, 2009 | Acer Computers & Internet
Headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Mar 25, 2008 | Logitech Z-5300 Computer Speakers
Televison & Video Logo
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
