Question about AOC A20E221 20 in. EDTV-Ready LCD Television
Envision model A20E221 unit does not power on. Blue light blinks,no sound, no indication unit is on. Is it time for a new unit or is there a less costly fix?
  • AOC Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Now, the cost of repairs will determine whether or not you should purchase a new unit. If the cost of repairs is very expensive, then it would be better you go for a new unit.
I wish you good luck.
Posted on Nov 11, 2010
Have a power problem, will not power on
kindly provide model; make, brand and other details.
How many times does the rd light blink. count carefully that is a diagnostic code.
Mar 30, 2016 | Televison & Video
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Thomas
Dec 02, 2013 | Pioneer Televison & Video
Red flashing power light blinking
These flashes are fault indications, and are called blinking codes. By the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 10, 2013 | Insignia NS-LCD47HD-09 47 in. LCD TV
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Blink s blue light envision g218a
The blinking blue light indicates your power supply has blown out. The heat buildup in the case has caused parts called capacitors to blow and short the power supply causing the blinking. We offer a repair service for $30 plus return shipping. If you wan to do the repair yourself you will need to open the back of the monitor and look for the bulging capacitors. To see what the bad capacitors look like go to our site at: www.ccl-la.com Replace any bulging caps that you see and you should be back going. You will need to use high temp capacitors marked 105c. If you have any questions about the repair or repair service just let us know at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 07, 2009 | Envision G218A1 22 inch Monitors
Will not power up
try to disasemble ur video card then put it back again the open it...
Nov 08, 2009 | Envision G22LWK 22" LCD Monitor
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
AOC A20E221 20 in. EDTV-Ready LCD Television Logo
112 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
