Question about Danco Home
When installing the single handle mx-1, what washer should be in first at the hex end? Copper or plastic?
Cannot remove 1/8" hex nut on handle. I am trying to replace valve control due to a leaky faucet. Nut seems frozen. Mel
A faucet handle? In Automotive?
If you mean a sink faucet, what brand? Is it single lever? On some, it's not a hex; rather a narrow slotted screw.
Oct 15, 2016 | Cars & Trucks
How do I get the handle off
if it is a single handle or mixer tap
look under the handle and there will be a plastic plug ( probably red/blue ) pull that plug out and there will be a hex screw that will unscrew and allow the handle to come off
Apr 28, 2016 | Price Pfister " 808-TMYY Hanover Tub &...
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Faucet hex-screw not tightening correctly
Anytime you remove the screw you speak of there is a donut washer/seal made of rubber or plastic underneath that must be replaced even if it looks OK to the naked eye. The screw when tightened compresses the washer/seal which is made with a consistency that allows for no residual memory to return to it\'s original shape. The problem (or what makes them work so good) with them is that they form to the underside of the screw and the inside of the screw housing to provide a seal and this formation is basically impossible to place exactly as was when reassembling they fixture. Thus in order to not have it leak the need to make it too tight is prevalent or as you say the handle will turn willy-nilly due to being loose. It is an easy fix and they are cheap. The washer/seals can be purchased at any hardware type store and it should make it easier to tighten properly without your preceding problems.
Mar 24, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
Oil leak on poulan snow lower
follow this steps and fix it. God bless you
  • Remove the hex bolts holding the plastic leaf blower housing in place with your hex wrench. You may wish to cut the cord with your scissors and loosen the bolt or screw securing the rope assembly with your hex wrench or screwdriver.
  • 2 Remove the spring assembly carefully. Do not remove the spring, only remove the assembly.
  • 3 Remove the old cord from the leaf blower pull cord assembly by gently pulling it away from the assembly with your hands. Notice the direction the pull cord is wound, as this becomes important in the next step.
  • 4 Wind the new pull cord in the same direction you removed it in Step 3. Make sure the inner end of the pull cord secures in the faster or slot provided on the pull cord assembly. This varies depending on the leaf blower manufacturer.
  • 5 Replace the pull cord pulley and place over the spring. This is the white plastic spool.
  • 6 Rotate the pull cord assembly two or three times in the same direction the cord pulls wearing safety goggles and work gloves. Reinsert the center screw by screwing it in place with your screwdriver; this holds the pulley assembly together
  • 7 Insert the leaf blowers cord end into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new pull cord; this prevents the handle from being pulled off the pull cord while you start the leaf blower.
  • 8 Place the pull cord assembly back onto your leaf blower in its designated area and secure by refastening the four hex nuts with your hex wrench.
  • 9 Replace the housing cover of the leaf blower and refasten the hex nuts with your hex wrench. You removed the housing cover in Step 1.
Nov 24, 2013 | Garden
My shower faucet is leaking
this could be abad tap washer
a faulty loose pipe connection
or a faulty tap
turn of your water supply at the outside your house before proceeding
remove the handle on your tap then remove insert screw valve usually with a spanner or shifter
you should see a copper or plastic stem inside with a flat washer at the end which
http://www.videojug.com/film/how-to-fix-a-dripping-tap-bib-or-pillar
hope this helps
Nov 06, 2011 | Moen & One Handle Tub & Shower Faucet
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
Jan 29, 2011 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
I need to know how to remove cartridge for single handle shower. I got the very inner part out but the sleeve it fits in is still in the adapter.
it sound's like you pulled to hard and broke it.if you have a thin piece w/o-ring's made of copper,ya broke it.it will take some work to get out,a punch awl with the end bent slightly should do, the sleeve is made of plastic.
Mar 28, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Home Logo
42 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
