Question about Hayward 250kbtu Ng Pool Heater - Inground
I had a Hayward heater (LP gas) about 4 years--lost the manual. I'm not sure of the model # (it has been wash out by sunlight). The code is showing LO--pilot light out? How do I re-light it? Rojo
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
LO can mean several things: pressure switch fault or one of a few limit switch faults. All of these switches are found in the safety circuit. Your electronic unit does not have a pilot to light.
If you are able, you will need to use a digital multimeter or analog meter to trouble shoot the circuit and identify which one of the switches is open and either fix the situation causing it to open or replace the switch if it is faulty. I would start with the pressure switch since it is the most common part to open and/or fail.
The easiest first step would be to thoroughly clean your pump and filter system and see if the heater resumes operating normally. If not, check the pressure switch itself by jumping the two wires attached to it and see if the heater runs. BE SURE THE PUMP IS ON WHEN YOU DO THIS!
If the pressure switch is ok inspect the three limit switches next.
If you need a copy of the manual please contact me thru our site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 11, 2010
My hayward pool heater gives me a code sb what part is this
Possibly failed keypad, or stuck key on keypad.
This product should be under full warranty, and installer should be called.
Hayward 350 product manual: Error codes start page 38 do not show Sb
http://www.hayward-pool.com/pdf/manuals/Manual285.pdf
However Sb error code shows on following manual as 'Keypad failure' or 'stuck key'... one of the keys is stuck longer than 30 seconds, but control will still function, replace keypad.
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Sep 20, 2012 | Hayward H350FDP Low NOx Propane Gas Pool...
I have an H 300 propane heater showing an HF code, cleaned all gas orifices and replaced the ignitor. Still comes up with the HF code any ideas.
Here is an answer written by Stephen Dorje. I think it should help.
This means the flame sensor/ignitor has failed. You are either not getting spark or the burners are not igniting if you are getting spark, I would recommend replacing the sensor/ignitor. Pretty inexpensive and a fairly easy fix. Here is the owners manual for the unit (not Lo Nox)....
Hayward Heater Manual link
Answered by 8c79505.jpgStephen Dorje Over a year ago
Sep 03, 2011 | Hayward H Series Pool & Spa Heater 400k...
Heater has power but flashes code L.P
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
Our Hayward gas heater keeps giving us a H5 error code and then shuts off. What does this mean?
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow, allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 05, 2010 | Hayward Pool & Spa
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
May 25, 2009 | Hayward Pool Products Hayward 400k Lp H...
Hayward 250kbtu Ng Pool Heater - Inground Logo
65 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
