Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have a Whirlpool Ultimate Care II, Model # LSQ9010PW2. The basket spins sometimes, but not always. Once the cycle has ended, I can physically turn the basket until it "locks". After that it will spin. What's going on?
  • 4,323 Answers
Hi
This is happened due to loose wiring on the LID switch(part#11) or due to a faulty lid switch. The lid switch is inside the washing machine main housing near the door frame. To access it you'll have to open the top of the washing machine to get to the switch.
In case the lid switch is fine then it is due to direct drive coupling. You can gain access to the coupler easily. Unplug the washer. Turn off and disconnect water supply lines. Place towel in floor in front of washer. Tip the washer forward onto face of washer. Unplug wiring clip connector from drive motor. Remove 2 1/4 inch head screws from spring clips on bottom of motor housing. Slowly rotate clips out to drop motor. Remove the top coupling piece off agitator shaft with screwdriver and light hammer. Use a 5/8 deep well socket to replace the coupling. Now, put the other coupling onto the motor shaft using light hammer and drive socket(5/8). Place the rubber connector onto the agitator drive piece then slide the motor back into the mount position. Rotate the clips back into place. Tighten 1/4 head screws in clips re-attach the wiring harness, tip the washer back up. Please check part#13 (agitator coupling)---
Hope this helps.. Please post back if you need further assistance.
Daniel
Posted on Nov 11, 2010
Doesn't always spin out at the end of the wash and rise cycles.
sounds like a touchy lid safety switch that works for a while and then quits,its under the top cover and is activated by the lid plunger tab
Jul 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Whirlpool washer LSQ9549LW1- loud thunks at end of spin cycle
you can goto sears.com and goto parts, put in your model # and they have a parts and diagram that you can look at.. sound like your basket block (which holds your basket on the gear shaft) is loose.. or 3 bolts on bottom of washer the holds gearbox to frame is loose.. good luck
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LWP Top load
sounds like the basket drive. it is kind of a big job.you need to take out the gear case and then the basket drive. you need a special tool to get it out. the agitator comes off forst there is a spanner nut that you must take off.
Oct 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer basket has dropped 1.5"
Different models use different devices to "suspend" the tub. Please verify the exact make / model.
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
353 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
