Question about eMachines T3642 Refurbished AMD Desktop Computer - AMD Athlon 64 4000+ 2.6GHz, 1GB DDR2, 250GB SATA
My Emachine T2865 will not boot up, and just gives a continuous string of long beeps. What does that indicate?
  • 1,179 Answers
This is a problem with the RAM. It is all explained in my tip entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanking you
damnor01
Posted on Nov 12, 2010
My pc beeps when stars and the does not start completly it continues to give that beeping and the monitor does not display anything
The beeps in your computer at boot up mean that there is an hardware.
Every number and lenght of beep is a code that indicates where the error is. You should refer to your producers webpage to "translate" the code in the cause of boot failure
Feb 06, 2013 | HP Computers & Internet
Will not power on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | E-Machines Emachine T2865 Power Supply...
Green turn on button will not come on just orange lite. green button don't turn on at all nor will computer boot up. model T2865 bought in 2007
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
Apr 22, 2011 | E-Machines Emachine T2865 Power Supply...
I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD ATHLON THAT JUST CONTINUES A LONG REPEATING BEEP AT BOOT AND AM NOT RECIEVING SIGNAL TO MONITOR. IS IT MEMORY OR VIDEO . CAN'T GET A CLEAR TOPIC FOR THE...
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
Nov 23, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Mt Emachine T2865 cant get any video?
Do you mean you cant play video?
Try install VLC player, it has all the codecs built in.
If this is not your problem, please give some more details
Aug 02, 2010 | E-Machines Computers & Internet
I have GA945GCM MOBO. While booting it gives continuous beep. If any keyboard key is pressed it stops. The keyboard spacebar key is not functioning. After boot in windows XP, the keyboard problem (spacebar...
Hi shreepad,
Those sound like you have a bad memory chip DRAM or it may not be seated correctly. The beep code of 1 long beep, also indicates a bad memory chip. If you have two or more, take one out and until you find the one that's bad. Then replace it.
Good Luck
Mark
Nov 24, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
On boot up the emachine now beeps every 5 seconds
Reboot with "F8" held down.
you are only booting to bios and minimum disk software. This may give you an indication of your monitor or video driver status.
If you can borrow another monitor from someone, that would confirm your monitors status....
Oct 14, 2009 | E-Machines eMachines Desktop PC
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
AU31 Board
Do you hear the system POST (Power On Self Test). In layman's terms that's when the system beeps and does a systems check. If you don't here this, the motherboard is usually dead. It could be another component though.
So, if you disconnect everything externally and internally down to the CPU and a few RAM chips (only what's required to do a POST) and a keyboard, to then see if it POSTs.
If it doesn't POST, then, if possible, try a new CPU, RAM, and Keyboard, other than this, you would replace the motherboard.
If it POSTs, you need to let us know how far it gets in the boot process and what error messages appear. If the boot is short of successful, you can still do the same things listed above to see which component is failing. The replace it. A process of elimination.
Nov 25, 2007 | E-Machines eMachines Desktop PC
eMachines T3642 Refurbished AMD Desktop Computer - AMD Athlon 64 4000+ 2.6GHz, 1GB DDR2, 250GB SATA Logo
236 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
