Question about Janome Sewing Machines
How do I correct the tension on my Janome sr2000 if I can see the bottom loops on the top of the material?
  • 323 Answers
SOURCE: noise from bobbin case on new Janome 4020
Check the bobbin to be sure it is inserted correctly. When you pull on the bobbin thread the bobbin should turn to the left(orcounterclockwise). If it doesn't, the thread will come out of the bobbin tension and give you loose stitches on top of the fabric. It will also make a noise because the bobbin is bouncing up and down.you will need to readjust your tension again.
sewman7
Posted on Dec 24, 2008
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
bargainbox
  • 1388 Answers
SOURCE: tension
Bobbin Tension is too loose......probably thread/lint trapped in the spring tension of the bobbin case.
Check this tutorial for all things tension....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 02, 2009
bargainbox
  • 1388 Answers
SOURCE: top tension is making a loop as I sew, bottom
TOP THREAD TENSION:
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
bargainbox.com.au
Posted on Aug 19, 2009
  • 2973 Answers
SOURCE: Pfaff sewing machine 1469.
It is not that the thread is not being picked, it is just that the tension of both the top and bottom threads is not equal. That is why the thread at the bottom gets collected because the lower thread is loose compared to the top one. Loosen the top thread by unscrewing the thread tightner a little at a time. The problem will be sorted out when tension get equal or near equal.
Posted on Nov 30, 2009
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
How to fix tension? Janome 10000. Top thread looping on the bottom of the fabric.
Generally speaking, if there is thread looping on the bottom of the fabric the upper tension is incorrect or the tension disks are not engaged. Try completely untreading and re thread the machine with the pressure foot up. Then lower the pressure foot and see if you have tension when pulling gently on the thread. Try again.
Mar 07, 2015 | Janome Memory Craft 10000
Can't adjust the tension correctly
Make sure your machine is threaded properly. If your thread is looping to the bottom tighten the manual tension adjustment slightly and test again do this until it is the way you want .. If it is on top let the tension slightly until it is adjusted the way you desire..
Nov 13, 2013 | Janome Sewing Machines
My tension is very loose when I do freemotion quilting. It is fine on the top, but the bottom gets tangled. It sews fine when I have the walking foot on, but when I put on the different plate for...
Hi Leann: Think about how a sewing machine works. Now think about what kind of difference an 1/8th of an inch distance would make. Yes. You will need to adjust your top tension when you do free motion work. Keep in mind that plate is not just stopping your feed dogs from working... it's holding your materials that far away from the bed of the machine... so when the thread makes a loop and tightens for the stitch it has the extra 1/8th of an inch to make up for... if the tension isn't right... you got loops. There are no "specific" settings for tensions... you learn by doing you stitch a few stitches on like materials and tighten until you see a good stitch.
Sep 29, 2013 | Janome 1600P-DB Mechanical Sewing Machine
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Feb 25, 2013 | Janome Memory Craft 9000 Computerized...
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
The wrong loops are on the surface of the material that I've sewn
Loops on the top of the fabric are usually caused by the bobbin thread not in the bobbin case tension correctly, remove the bobbin and reinstall it. You should feel a slight resistance when you pull on the bobbin thread.
May 29, 2010 | Brother CS6000i Computerized Sewing...
Janome 314. Multiple loops on underside of material. Why?? How to correct??
not enough tension on your needle thread is the most common cause of this problem. rethread and make sure there is sufficient tension on the needle thread.
Aug 30, 2009 | Janome Sewing Machines
Noise from bobbin case on new Janome 4020
sewman7
Dec 22, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
