Question about Toshiba Satellite A215-S7462 Laptop
The touchpad does not work. Device manager will not recognize. It will recognize Microsoft mouse. Tried downloading the driver from synaptics.
5 Suggested Answers
  • 236 Answers
SOURCE: CD/DVD drive isn't recognized / cannot load driver
what is your operating system? have you upgraded yo a higher version? if you did then you must have installed a driver thatis not designed to work withy our OS now.
Posted on Apr 02, 2008
1234s282
  • 144 Answers
SOURCE: synaptics pointing device ceased to function
Load up device manager , highlight your computer (top in the list) and right click - select scan for new hardware - See if it detects your pointing device now
If it does , right click it , update driver etc and reinstall the drivers for it
If not , it might be a hardware problem , try getting it repaired by toshiba if its still under warranty
Posted on Jan 04, 2009
leecom72
  • 4806 Answers
SOURCE: Touchpad does not function
It sounds to me like the touchpad drivers are corrupt and need reinstalling.
Go here to Toshiba support, download and install the touchpad drivers and utility and see if that helps.>>>>>>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1845344&rpn=PSL48U&modelFilter=L45-S7419&selCategory=3&selFamily=1073768663
Good luck and please post back if you need anymore help or advice.
Regards.
Posted on Aug 17, 2009
Testimonial: "Thanks a lot!! It worked. "
  • 104 Answers
SOURCE: touchpad is not working and does not show up in
You need to reinstall the Synaptics driver from Toshiba. If you do not have the Toshiba driver CD for your laptop you can try the generic ones from : http://www.synaptics.com/support/drivers
The touch pad may also be disabled in the system bios, (ie the options before you boot through to windows) Re enable it there if you are sure it is not a driver problem.
If still no joy, your local Toshiba agent can advise free on rectification, but you have to take the notebook in to them.
Hope this helps.
Posted on May 27, 2010
Error: Unable to connect to the synaptics pointing device driver
What you need to do is go to device manager by clicking on start and control panel and find the device manager. You can also type devmgmr.msc and hit enter. Then you can see the pointer devices. You can then delete them and the right one will come back when you restart the computer you can then go back to the device manager and disable it there.
Sep 17, 2014 | Dell Inspiron 15-5547 Notebook...
Touchpad not working
There's a tiny orange light near the upper left corner of the touchpad to the left of the touchpad. If that is lit, you may only have to tap the upper left hand corner of the touchpad a couple of times to get it to go out. and start the touchpad working.
Barring that, see if the synaptics driver is installed. Go to "Control Panel," change the "view" in the upper right hand corner to "large icons," and see if "Synaptics Touchpad V8.1" is listed.
If not, go to "Control Panel," locate device manager and click (with a usb mouse) "mice and other pointing devices," click "Synaptics PS/2 Port Touchpad," and check to see if it says, "device is working properly." If not or if it still doesn't work, click the driver tab, and click "update driver."
Dec 08, 2012 | HP elitebook 8760w
My acer aspire 4339 synaptics touchpad isn't working
try to enroll to earler system settings windows - start - control panel - recovery, if not help, try to check touchpad connection
Nov 11, 2012 | Computers & Internet
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign.
If synaptics is listed right click and select Uninstall.
After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Thanks for using FixYa - If you
Apr 29, 2009 | Logitech Marble Mouse Trackball
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
I think I can help you. I need to know what kind of mouse driver you are using. To find out click on the control panel, click on mouse properties, click on device settings. Under devices it should show Enabled/Name/Port. Under Enabled it should say Yes. Under Name should give the name of the device being used and under Port it may or may not show anything. Ex. Yes /Synaptic TouchPad V7.2 / Port/2. If this is what yours shows, double click on the highlighted device and a menu will come up. From there you can reactivate your scrollbar. If yours does not show a device in the list, sometimes it will show where to go to download the device in the bottom righthand corner. EX:(www.synaptics.com) If not, you will have to find the name of your device. Hope this helps. Tim
Jan 10, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Try to reinstall your driver. Download it from here: driverupdate us . This tool usually keep my drivers up to date (perfectly for now) take a look
Jun 09, 2007 | Logitech Marble Mouse Trackball
Toshiba Satellite A215-S7462 Laptop Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
