Question about Foxconn 400M01-G-6L Motherboard
Foxconn 400Mo1-G-6L Motherboard installing 4 bay media card reader, wire connector has 4 female + plus one blocked connector, which jack on the motherboard do I plug into?
  • abothfeld Nov 11, 2010
    Thanks Eksa,
    I pluged it in and fired it up and tested it.
    Many Thanks to you and FixYa
    Andrew
    Yes this worked the first time - thanks very much for the quick turn-around to this problem.
  • 13,433 Answers
Hey
To a USB header.
The bottom row of pins
Let me know if you need anything else I'll respond as soon as possible.
Thanks, Ekse
Posted on Nov 11, 2010
  • Ekse Nov 11, 2010
    Thanks Andrew, if you need anything else let me know, or hit the accept button below.
Why there is no power of foxconn motherboard g31
Many potential reasons--unfortunately including motherboard DOA, mem DOA, CPU DOA.
Sometimes, even a mere bum PCI-E I/O card will halt function completely, too! Removing such a card may restore nominal function.
Is the heatsink installed correctly--with the correct amount of thermal paste? Is the fan connected to the motherboard fan connectors? Is the secondary power connector from the power supply connected? It's the power connector which fits a special motherboard socket of 4 or 8 pins--that's in addition to the main connector with 20- or 24-pins. (This is not a high-powered PCI-E video card dedicated-power connector!)
Jul 17, 2014 | Foxconn Computers & Internet
HP Pavilion p6310y Desktop PC front panel wiring
Hello here is the homepage:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&tmp_geoLoc=true&product=4120042
The front panel connector look like this:
It`s located down the right corner of the mainboard.
Good luck
Dec 27, 2012 | ASUS M2N68-LA Motherboard
I need the technical specifications
This Dell WEB site has the specification of the Dell Latitude E6410 -
http://www.dell.com/us/business/p/latitude-e6410/pd
Feb 09, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
Replacing a mcp61pm-hm nettle2 mobo in my hp forgot wire placemen
The little white plug sounds like the audio connector. Most usually you do not have to hook this wire up. The sata connection from the drive to the mobo should take care of everything. Most usually this plug in is for connection directly to a after market sound card. The little black plug coming from the media bay you speak of sounds like the front side usb connector. It may also include the front mic and headphone jack. Please check to see if the black plug actually attaches to the front of the pc near the power buttons.
Aug 25, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Front panel connections
can someone help me on how to wire fp1 on foxconn motherboard
Sep 16, 2008 | Foxconn 848P7MB-S Motherboard
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Feb 02, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
Foxconn K7S741GXMG-6L Sound issues
maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Jan 26, 2007 | Foxconn K7S741GXMG-6L Motherboard
Foxconn 400M01-G-6L Motherboard Logo
393 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
