Question about Craftsman 24 Hp 48" Deck Yard Tractor
Hi, My YTS 4000 is shutting down after mowing for a short period. I believe it is not getting fuel flow. could you assist with this problem?
No professional, but my father's Murray did the same thing a few years back and it was the Coil going bad. Replaced it and it was fixed. Hope this helps.
Posted on Dec 12, 2010
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Why does my john deere L100 shut down during my mowing?
Your cap should vent, it is bad so replace it. The vacuum is holding back the flow of fuel. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 24, 2014 | John Deere L100 Series
Craftman yts 3000, 21 hp., 46
To die suddenly does not point to the plug. Sounds like something may have shorted out and caused the loss of spark. Try to locate an inline spark tester and see if you have spark when trying to start the unit. Also check the harness for worn wires.
Jul 15, 2017 | Craftsman Garden
18.5 hp Briggs & Stratton no spark after running out of gas
I believe you are right about heat induce electrical problem.
About all there is for ignition is the coil and breaker points.
Mar 05, 2017 | Briggs & Stratton Measuring Tools &...
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
Lawnmower shuts off after 15-20 mins of running
Sounds like a bad coil to me ... it only makes sense that has the heat from the engine transfers into the coil the coil windings expand and causes a open resulting in ignition failure and no spark to the plugs... if you need parts try www.partstree.com
Aug 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
Try to restart to see what happens. However, make sure to have a volt meter to check output voltage. You may be loosing voltage and therefore it shuts down. Check oil pressure switch, rings, brushes. Replace brushes if they are less than 1/2" short and clean rings with emory cloth until copper is noticable.
Jan 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
250 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
