Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
How to replace sproket what tools needed - Echo 30.1CC Chainsaw With a 14 In.bar and Chain
  • 7,733 Answers
Look at eReplacementParts.com and the parts diagrams
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
How to replace stator 2005 Harley deluxe
Hi Anonymous, if you are going to work on your bike your going to need tools, and the first and best tool you will ever buy is a service manual. It has step by step instructions, how too's, pictures, special tools you will need, torque specs, special products (loc-tite, sealants, cleaners ect.) and wiring diagrams, along with trouble shooting tips. That being said here is the short version: Drain primary oil, remove primary cover, clutch pak, primary chain, compensating sproket, and alternator rotor to access stator. Good luck
Apr 13, 2014 | 2005 Harley Davidson FLSTNI Softail Deluxe
Timing camshaft
for gti engine , you will need a timing tool
this one has both timing belt and chain, first you need to line up the chain and it will require the timing tool .
for the belt there should be two marks one on the cam sproket and one on the crank sproket. you will have to line up the marks with ( OT).
Apr 02, 2014 | 2006 Volkswagen GTI
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
How do i get the sprocket off
If you mean a front sproket, it is likely to be held on by 4 or 4 bolts to the crank arm.
If you mean the rear cassett, you will need a chain whip and a lockring tool. Hold the sproket still with the chain whip then undo the locking with the tool.
Feb 28, 2011 | Cycling
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
How do i time a 2002 dogde neon?
you need to take apart all the front of the engine until you get to the timing belt,once you are there,you are going to look for the marks on the sprokets,in the crank shaft sproket is a dot,align it whit the triangle that you are going to see back housing,the cam shaft sprokets you are going to see the marks.on the right sproket it is going to be slightly half dent foward.
Sep 29, 2010 | 2002 Dodge Neon
2001 pt cruiser. Timing is not aligned. The holding tool I used to remove the cam sprokets slipped. The exhaust sproket is 180 off. How do I fix that without screwing up the valves/pistons
you can fix this by setting the bottom end of the engine center stroke then rotate the cams to the proper alignment markrotate the bottom end slowly in a clockwise motion back to top dead center :)
Jul 13, 2010 | 2001 Chrysler PT Cruiser
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
S60. 2.4T removing and replacing timing belt
remove auxilary belt remove one bolt from timing belt cover remove cover turn engine to tdc using socket on crank nut check cam pulleys lined mark with white paint or tipex remove 4 bolts on crank pulley then centre pulley nut use impact gun prise of pulley check all marks still lined up buy or borrow universal cam sproket lock tool this is important to stop cams moving when belt of release tensioer remove belt chek water pump for leaks and wear fit new tensioner then new belt keep tight on non tension side feed over sprokets tension belt to align pointer on tensioner turn engin 2 times re check timing marks fit all parts removed
Nov 23, 2009 | 2001 Volvo S60
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
