FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
MoBo Winfast 6100M2MA-RS2H
posted by Chaard on Jun 17, 2008
i have the same motherboard as you and after moving to a new case i can not remember the way the power switch connecters were connected! please could you tell me the config in yours or even send me a pic of the power switch connectors in situ!.
thanks a lot!
Rich x
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 19, 2008
Not Rated (0)
worldvet
Rank:Guru Guru
Rating: 89%, 219 votes
This board is made by FoxConn.
Looking up towards the CPU from the bottom the front panel connector is the third connector up from the bottom right and/or should be labeled as show.
This motherboard is made primarily by FoxConn
This is the link to the English Manual download page.
Regards,
Worldvet
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP (D7580-60003) Motherboard Apple (661-2795) for iMac Motherboard ASUS P5PE-VM Motherboard ASUS P4P800 SE (890552603657) Motherboard ASUS P4S800-MX Motherboard ASUS (M2NGREEN) Motherboard ASUS P5B-E Motherboard
Can you Help with these Motherboards problems?
EPoX EP-8KMM3I-X Motherboard
Motherboard EP-8KMM3I
Where can I get a manual for... Answer This...
Motherboard NO Boot
PC been working fine, turned on... Answer This...
Intel D845GVSR Motherboard
how i show the cahs memory?
how i show the cahs memory? Answer This...
Motherboards
VGA Port not giving output
My Monitor on Desktop is... Answer This...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
bios resets to 07-31-2007 when...
bios resets its self when i... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
