Question about Pyramat PM550 Sound Lounger Universal
I received a Pyramat PM550 from my next door neighbors but there are no hook ups or wiring instructions included with it. Is it possible to purchase only the hook up equipment req'd or should I just toss it?
Merlin powerlift 2500l
Check your own remotes ! If you have an extra in a junk draw every time you open and close the draw you can possibly have something bump up against one of the buttons and with their sensitive buttons they can easily be triggered.....I had a customer that was happening to her . Another situation could be leaving a remote in a pocket or purse ...again these buttons don,t need much to send a signal to your opener without you even realizing it! Another situation I have seen is a neighbor having the same age machine as you ..the frequency transmitting signal has changed over the years because of interference from other remotes or microphone signals such as police radio,s ..ambulance...fire stations all use these frequencys , also local airports and private planes all transmit these signals ...even your neighbors remotes were a problem until they came up with rolling code technology , if you have this then you should not have any interference from any outside signals and you probably have a remte laying around that's getting bumped ! If you and a neighbor have similar machines from earlier then 1985 then you probably have a garage door opener with dip switch technology ....On the dip switch settings you have to set your own code but most people had them installed straight out of the box without any code changing and left the factory settings to 0....Well most likely your neighbor also did not change from the factory settings and that can be another scenario....These are all things I have seen as a garage door mechanic and could be possible scenario,s for troubleshooting your problem , Hope I was able to help you but if all else fails then definetly go with a new receiver kit because it would definetly have rolling code technology
Apr 12, 2014 | Building Materials
Hey, I've got a Craftsman 1/2hp garage door opener circa 1991 that is picking up the signal from my neighbor's remote. Tried resetting the pins a few times and tried leaving it unplugged for a few days to...
Hello bj.... wow....what are the chances... there are pins in the remote and on the back of the motor. reset both to the same settings and you should be fine. Joe
Mar 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens by itself. Maybe neighbor has same code?
This is generally caused by a bad wall control or the wiring going to it. Make sure there are no staples cutting through the insulation. You can temporarily remove both of these possibilities by removing the wire at terminal #1 on the rear of the motor unit. You can then hook that wire back up and remove one of the wires from the back of the wall control.
Jan 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
HAVE SEARS/CHAMBERLAIN "91"MODEL 53615SR AND NEIGHBORS OPENER KEEPS OPENING OUR GARAGE DOOR BUT OUR OPENERS WONT OPEN HIS
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
Pyramat gamebag instructions
Go to this link and pick your model and download owner's manual:
http://pyramat.custhelp.com/cgi-bin/pyramat.cfg/php/enduser/std_alp.php?p_accessibility=0&p_redirect=&p_lva=&p_sp=&p_li=&advsearchmode=0&p_new_search=1&p_search_text=game+bag+owners+manual
You may need to copy and paste the entire link. If this helps, give me a good rating. Good luck.
Oct 16, 2009 | Computers & Internet
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
S2000 sound rocker
Go to this site you will get all the answers you are looking for. As for th cables you need to get the proof of purchase.
http://pyramat.custhelp.com/cgi-bin/pyramat.cfg/php/enduser/std_alp.php?p_accessibility=0&p_redirect=&p_lva=&p_sp=&p_li=&advsearchmode=0&p_new_search=1&p_search_text=s2000
Good Luck and Please Rate FixYa!
Dec 28, 2008 | Pyramat S2000 Sound Rocker for Xbox
Pyramat PM550 Sound Lounger Universal Logo
66 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
Michel Laprise Sr
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
