Question about Thomson Lyra PDP2860 Digital Media Player
Problem turning on
When turned on screen says reset after unplugging USB,
any ideas
I have had that problem a few times, it started after i did a firmware update, so i just undid all the screws holding the back on,(including the 2 under the cf card slot's cover) and unplugged the battery for 10 seconds and plugged it back in and it worked fine.
Posted on Jan 21, 2010
LG 55LE5400 LED TV will power up, but only shows black screen with no picture and no sound. Any ideas?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 11, 2016 | LG 55LE5400 TV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
Can't reset access password. When I start the laptop I am getting a prompt for an access password. I have tried doing the password reset procedure of unplugging the laptop, taking out the battery,...
You method is used to remove the BIOS password, not Windows log on screen password.
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully. You can have a try.
Feb 10, 2011 | Lenovo ThinkPad T510 4314 Core i5 540M 53...
Sony walkman nwz-e438f won't start up
check that your not plugged in to a usb hub, my hub is USB 1. When I connect direct to a USB2 port problem solved!!
Jan 04, 2009 | Sony NWZ-E438F Digital Media Player
My coby mp3 player will not turn on
from what i have been experiencing, the coby will shut off when unplugged from your computer. Hold the power button for at least 20 seconds and it will turn on.
Dec 26, 2008 | Coby MP300 MP3 Player
Tom Tom go 910 screen get frozen every time I turn it on
Sounds like your firmware is corrupted. I have fixed a few 910's with this same problem. If you have the Tom Tom Home program installed, try to reinstall the firmware using Tom Tom's website.
Make sure you always select to disconnect the device before unplugging it. You might have unplugged it from the PC while it was still writing data. This will certainly corrupt the firmware.
- Jim
Nov 14, 2008 | Tomtom ONE 3rd Edition GPS
Wont turn on
hiya!! i have one of these pesky things. it has a mind of its own!! u need to reset it by pressing "previous track" and "volume up" buttons (in that order). screen should go blank, then turn on as normal. also i would recommend updating firmware to version 6.6 at www. phillips support
Sep 22, 2008 | Philips HDD120 MP3 Player
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Thomson Lyra PDP2860 Digital Media Player Logo
114 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
